88 dx engine, 90 si tranny... what clutch?
Old Jan 3, 2004 | 07:24 AM
kekek-20's Avatar
New User
Default 88 dx engine, 90 si tranny... what clutch?
i think the clutch in my dad's 4g took a crap.. won't go into gear when the engine is running.
as the title says.. 88 dx engine, 90 si tranny- what clutch? i can't remember which one i used when i dropped the engine in.
thanks!
dan
Old Jan 3, 2004 | 08:02 AM
91civicDXdude's Avatar
90-91 clutch
Old Jan 3, 2004 | 09:13 AM
dingusjt's Avatar
Default Re: (91civicDXdude)
you need to 90-91 flywheel on that too right?
Old Jan 3, 2004 | 09:14 AM
dingusjt's Avatar
Default Re: (dingusjt)
wait scratch that comment if he was already running it then it must be the right flywheel
Old Jan 4, 2004 | 06:47 AM
kekek-20's Avatar
New User
thanks for the help guys.
Old Jan 4, 2004 | 06:50 AM
crxgator's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dingusjt &raquo;</TD></TR><TR><TD CLASS="quote">wait scratch that comment if he was already running it then it must be the right flywheel </TD></TR></TABLE>
kinda correct...he could have thrown in an 89 flywheel instead...so only way to really find out would be take out the clutch disk and measure it...
Old Jan 4, 2004 | 08:44 AM
kekek-20's Avatar
New User
Default Re: (crxgator)
yeah, can't remember which flywheel i used. we were in a hurry to get the car running so we swapped it real quick. only 1 of the 2 flywheels worked so we went with it.
what's the difference between clutches in the d-series.. the amount of splines? or is there even a difference between an 88 and 90? i guess i can always bring the old clutch to autozone and match it up with the new one.
thanks,
dan
Old Jan 4, 2004 | 08:48 AM
crxgator's Avatar
Default Re: (kekek-20)
88 has different splines (i think 23)
89-91 same splines (i think 21)
89 200mm clutch disk
90-91 212mm clutch disk
im not 100% sure, but thats the number i remember off the top of my head...
Old Jan 4, 2004 | 10:47 AM
virginia_dude's Avatar
Default Re: 88 dx engine, 90 si tranny... what clutch? (kekek-20)
if he has a 88 engine and flywheel he needs a 89 clutch, it will have the spline count of the 90Si tranny and fit the smaller 88 flywheel. Unless he scores a 90-91 flywheel then he can runn the larger 90-91 clutch.
Old Jan 4, 2004 | 01:06 PM
kekek-20's Avatar
New User
i just pulled the tranny and the clutch puked a spring. dad must've been roasting the tires.
20 splines and 212mm diameter disc - looks like it's a 90-91
thanks!
Old Jan 4, 2004 | 01:09 PM
crxgator's Avatar
good deal...upgrade it to an ACT for your draggster dad...
Old Jan 4, 2004 | 01:50 PM
Outsane's Avatar
i got a 90 act clutch and disk I need to get rid of...pm me if your interested
black88si
10
Mar 13, 2007 05:58 PM
tuname420
Aug 31, 2006 09:44 PM
dwerpk
Jun 5, 2006 05:09 PM
CRXalwysk8
13
May 3, 2005 07:18 AM
90DX
Jul 18, 2004 03:38 PM
