My integra Full of water...nice....
Old Jan 2, 2004 | 11:08 PM
Vinhtran17's Avatar
Default My integra Full of water...nice....
My 95 LS interior is full of water now.... since of the rainy season now here in gay pleasanton,CA , i now see that my whole flooring in my car is like wet..( like i can slap my flooring inside and see splatters kumming out of the carpet....i also see that when i lift the cardboard in my trunk where the spare is.... it is like a pool in there... like maybe an inch of water.... im not sure wheres its kumming from.. (mayb the trunk or i dunno) is it my water sealant worn out or sumtin.... i need sume help.. thanks to all that helped.....
Old Jan 2, 2004 | 11:15 PM
sjteg's Avatar
Default Re: My integra Full of water...nice.... (Vinhtran17)
damn that sucks. Did you get the car used?
Old Jan 2, 2004 | 11:30 PM
TeGGY_LS's Avatar
Default Re: My integra Full of water...nice.... (sjteg)
yea i have water in my trunk......all the moisture is only on the passenger side of the trunk only. i looked to see if i can find where the water is comming in thru. It only gets wet when it rains. anyone know where the water is comming from. This is really bothering me......thanks
oh yea it also looks like there is water in my passenger side tail light too?
Modified by TeGGY_LS at 8:40 AM 1/3/2004
Old Jan 2, 2004 | 11:40 PM
ragejed's Avatar
Default Re: My integra Full of water...nice.... (TeGGY_LS)
Check my sig. Taillight gaskets are known to cause this problem.
Old Jan 2, 2004 | 11:58 PM
TeGGY_LS's Avatar
Default Re: My integra Full of water...nice.... (ragejed)
you take money orders?
Old Jan 3, 2004 | 12:32 AM
Kwuaymaikrup's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ragejed &raquo;</TD></TR><TR><TD CLASS="quote">Check my sig. Taillight gaskets are known to cause this problem.</TD></TR></TABLE>
Agreed. I had the same problem on both my tegs, G2 and G3. When I would drive and hit the breaks the water would roll up under the back seat and get it wet. Definatelly check the gaskets.
-Ryan
Old Jan 3, 2004 | 08:37 AM
Vinhtran17's Avatar
_______
98 SSB DC2
yeah i bought it at a used acura dealership about 4 months ago
Old Jan 3, 2004 | 09:54 AM
sjteg's Avatar
Default Re: (Vinhtran17)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vinhtran17 &raquo;</TD></TR><TR><TD CLASS="quote">damn that sucks. Did you get the car used?
_______
98 SSB DC2
yeah i bought it at a used acura dealership about 4 months ago</TD></TR></TABLE>
lol somehow you copied my post down to my sig and then added your response to the sig. I think you meant to quote what i said, theres a quote button you can use to help you.
Old Jan 3, 2004 | 10:35 AM
mozismozis's Avatar
i had the exact problem with my car (only in the trunk) there was about 2 inches or more of water sitting with the spare tire. it took me some time to figure out where the water was coming in from.
i had to remove both tail lights, buy new foam inserts, that sit between the tail light and the car. this is probably what's causing your problem. they've probably worn out. use a lot of clear silicone gel to stick the foam to the car. it wouldn't hurt to use the gel on the inside trunk of the car, sealing any spots you think might be giving you a hassle.
i hope this helps. it did for me.
lates
Old Jan 3, 2004 | 10:37 AM
SIK IN DA HED's Avatar
New User
ouch. that sucks. i would invest in a car cover in the meantime.
Old Jan 3, 2004 | 02:19 PM
superstud's Avatar
i had water in my tire well a while ago. i found that it was coming in through the bolthole closest to the center of the car on the driver side taillight. i just siliconed it up and voila! problem solved!!
btw this is in a 3G teg
Old Jan 3, 2004 | 02:48 PM
psdvette's Avatar
It could also be the sunroof drain plugs if you do have a sunroof on your car. That's why mine had been leaking before.
Old Jan 4, 2004 | 10:36 PM
Vinhtran17's Avatar
thanks guys for the help
Old Jan 4, 2004 | 11:03 PM
RedLinin247
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vinhtran17 &raquo;</TD></TR><TR><TD CLASS="quote">My 95 LS interior is full of water now.... since of the rainy season now here in gay pleasanton,CA , i now see that my whole flooring in my car is like wet..( like i can slap my flooring inside and see splatters kumming out of the carpet....i also see that when i lift the cardboard in my trunk where the spare is.... it is like a pool in there... like maybe an inch of water.... im not sure wheres its kumming from.. (mayb the trunk or i dunno) is it my water sealant worn out or sumtin.... i need sume help.. thanks to all that helped.....</TD></TR></TABLE>
First of all, wow nvm. Try replacing the weather strippin on your doors/trunk.
EDIT: Learn to use spell check. Spelling&gt;You
Old Jan 4, 2004 | 11:26 PM
es four's Avatar
From: You can be my wingman anytime...., Las Vegas, US
Default Re: My integra Full of water...nice.... (RedLinin247)
damn dude, that sucks.
Be sure to clean the hell out of your interior now. Even maybe have it done professionally.
Old Jan 5, 2004 | 05:12 AM
Creep's Avatar
Default Re: My integra Full of water...nice.... (integra707)
I would say its the taillight gaskets too, it happend on both of my integras.
My g2 was flodded so bad that back seats were getting soaked.
Old Jan 5, 2004 | 05:23 AM
Xymox's Avatar
Kumming? What's this? Some type of ghetto slang for coming?
Old Jan 5, 2004 | 06:43 AM
Egg-weezy's Avatar
Default Re: (Xymox)
you know what he means stop being a dick.
Old Jan 5, 2004 | 08:40 AM
Devlins 91LS's Avatar
Default Re: (psdvette)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by psdvette &raquo;</TD></TR><TR><TD CLASS="quote">It could also be the sunroof drain plugs if you do have a sunroof on your car. That's why mine had been leaking before.</TD></TR></TABLE>
werd thats what i was gonna say.
If your taillights are leaking, there'll be water in them. If they're completely dry, pull out your interior and the plastic body panels in the trunk on the passenger side.
There should be a little vent, a hose, and a plug. If the hose isn't plugged into the plug. BAM problem solved.
IMO i'd check that before you dump $100 on taillights.
Old Jan 5, 2004 | 08:47 AM
VTECorona's Avatar
Default Re: (Devlins 91LS)
Water got in half of my interior too when I had my hydrolock incident. When I opened my door to get out water came in only on the drivers side. It gets a little smelly while it dries out but the smell goes away when it dries.
Old Jan 5, 2004 | 09:00 AM
Spoodge's Avatar
From: Slut City aka San Diego, Ca, United State Of King
u will end up taking out all ur carpet.. if yuor floor is that wet.. because it is really hard to dry it well.. if water sits for to long you will get mold and your car will smell funny.. water came in my car from the spare tire area. i just took everything out and start siliconing all the holes.. next try the sunroof drain hose..if it is not that..strip down the whole car and start silconing the whole car....
Old Jan 5, 2004 | 09:54 AM
lke2drvgsr's Avatar
Default Re: (SpoodgeDc2)
its the drain tubes from the sunroof... behind the right rear interior panel in ur trunk there should be some hoses there.. one of the hoses came off and the water is just draining into the trunk/interior... check that
im having the same problem. i pulled my rear seats and they were drenched, my whole car is soaked, im fixing that all (hopefully) on thursday
Modified by lke2drvgsr at 2:13 PM 1/5/2004
Old Jan 5, 2004 | 01:54 PM
lke2drvgsr's Avatar
Default Re: (balch104)
buy a new gasket
Old Jan 5, 2004 | 05:23 PM
ragejed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by balch104 &raquo;</TD></TR><TR><TD CLASS="quote">Ok its the taillight that is leaking water inside.. how can i fix the problem?</TD></TR></TABLE>
Check my sig.
Old Jan 5, 2004 | 10:51 PM
Vinhtran17's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedLinin247 &raquo;</TD></TR><TR><TD CLASS="quote">
First of all, wow nvm . Try replacing the weather strippin on your doors/trunk.
EDIT: Learn to use spell check. Spelling&gt;You</TD></TR></TABLE>
Thanks for your help...But I think you need a bit of Spelling Check of your own
