JDM ITR cluster pin diagram?
Old Jan 2, 2004 | 05:48 PM
JjuuN R's Avatar
Default JDM ITR cluster pin diagram?
ok i did a search on a couple things and can't come up with anything, sorry don't have alot of time right now.
trying to put in a JDM cluster but i don't know what wires have to be crossed over and such to get the cluster to work properly. everything lights up fine, but the temp guage reads all the way hot, and the fuel guage reads all the way empty. when i turn my turn signals on they both go on (in the cluster) and the high beam light goes on.
anyone have any difficulties with this as well? help is thanks
Old Jan 2, 2004 | 05:51 PM
B2FiNiTY's Avatar
Default Re: JDM ITR cluster pin diagram? (JUN.R)
Just swap the gauges OR swap the green film.
JDM gauges in USDM cluster OR usdm green film on the JDM cluster.
Old Jan 2, 2004 | 05:53 PM
Mires's Avatar
I am guessing you have an integra. For one thing you are making it harder than it is. Just switch the back halves of each one (the white part) then plug in like normal. PM me if you have trouble.
Old Jan 2, 2004 | 08:55 PM
JjuuN R's Avatar
thanks a ton guys
Old Jan 2, 2004 | 09:08 PM
JjuuN R's Avatar
one more question on the cluster. are the 96/97/98 clusters a little different then the 00/01 years? i looked at it and the one i have and it don't have the SRS/ABS/Key Immobilizer/Maintinece Required lights. i'm guessing the 00-01 JDM clusters have what's missing on 96-98? everything else looks good though.
it does have an extra light in-between the oil and CEL light, looks like a chevy bowtie with vapors (squiggly) lines coming from the top of it. is this an overheating light?
sorry for the questions, just want to get things cleared up. thanks ahead of time!
Old Jan 2, 2004 | 10:09 PM
DC2fanboy's Avatar
Default Re: (JUN.R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JUN.R &raquo;</TD></TR><TR><TD CLASS="quote">
From what I remember, that's the catalytic converter overheat light?
Old Jan 2, 2004 | 10:29 PM
B2FiNiTY's Avatar
Default Re: (DC2fanboy)
Yeah that's for the cat.
The USDM 00-01 have the key icon which means the car has an imobolizer.
The jdm clusters do not have that. Also many do not have the abs light.
The 96 spec and 98 spec itr clusters have minor changes where icons moved.
Old Jan 4, 2004 | 01:14 PM
JjuuN R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2fanboy &raquo;</TD></TR><TR><TD CLASS="quote">
From what I remember, that's the catalytic converter overheat light? </TD></TR></TABLE>
thanks
so most of the JDM clusters are identicle for all of the years?
Old Jan 4, 2004 | 01:27 PM
Kicker773's Avatar
Default Re: JDM ITR cluster pin diagram? (B2FiNiTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">Just swap the gauges OR swap the green film.
JDM gauges in USDM cluster OR usdm green film on the JDM cluster. </TD></TR></TABLE>
did the exact same thing to mine.. worked out great.. i did a couple of customization such as switching not only the green film, but certain parts that indicated high beam, seat belt, etc. fastest way basically is to just switch the guages. So if you have a 98 n up there is room for your key code light
Old Jan 4, 2004 | 06:44 PM
JjuuN R's Avatar
nice, so basically take the JDM back half, and screw it on to the USDM front half. then take the UDSM circutry and put it in place of the JDM circutry?
just making sure before i take it back apart, HYBRID GUAGE CLUSTER!!
Old Jan 4, 2004 | 09:44 PM
Kicker773's Avatar
Default Re: (JUN.R)
be careful when you take it apart, there are three screws behind the green film on the jdm one n the usdm one. I accidentally missed it when i took everything apart and kinda cracked the carbon fiber just a tid bit. but yeah try not to make the same mistake i did good luck and take pics of it done n installed
Old Jan 5, 2004 | 02:48 PM
JjuuN R's Avatar
Default Re: (Kicker773)
yeah i noticed those screws deep down into the cluster, could easily be missed if you're not looking hard enough
Old Jan 5, 2004 | 03:18 PM
baonest1's Avatar
Default Re: (JUN.R)
easiest thing would be to just take the green film off of the USDM cluster, and put it on the JDM cluster. that is all that is required (well at least for my CDN cluster it was)..
Old Jan 5, 2004 | 03:39 PM
JjuuN R's Avatar
true that
Old Jan 9, 2004 | 04:22 PM
phdc2's Avatar
im trying to put a jdm type r cluster into my 01 integra. Its the jdm cluster w/o the srs light. Is it possible to keep all the icons in the cluster-the key imobilizer, maintance, etc? Whats the best way to do this swap?
Old Jan 9, 2004 | 04:27 PM
Kicker773's Avatar
Default Re: JDM ITR cluster pin diagram? (phdc2)
replace the whole back part of the udsm into the jdm one (the white piece/without the gauges).. just switch the guages of the jdm one into the usdm one, but you might have to transfer those small films/icons that indicate the things you want to see on the usdm ones.
phdc2's Avatar
Default Re: JDM ITR cluster pin diagram? (Kicker773)
how did u switch all the others parts. I own an 01 integra and i want to keep all the icons including the key, etc.
Old Jan 9, 2004 | 04:32 PM
Kicker773's Avatar
first you'd have to take the usdm apart.. (take the clear plastic off, the carbon fiber trimmings) until you can take off the usdm guages off the usdm one.
do the same for the jdm one. same process but make sure you've taken off the screws correctly/all of them.
swap the usdm guages and jdm guages. you should have the jdm guages onto the original white back part of the usdm cluster, and usdm guages onto the jdm one.
now on the usdm carbon fiber trimming you can pop out the thin film that indicates all the e-brake, srs, etc. do the necessary switches from the usdm and jdm ones.
now you should have the srs n abs option on the usdm back part of the cluster with just jdm guages..
GuitarSlinger78
Aug 16, 2008 01:38 PM
redline32
Oct 6, 2007 05:00 PM
import810
Dec 21, 2005 08:36 AM
Outkast_CL9
Jul 31, 2004 09:38 AM
funkyfreshdj
May 30, 2004 06:02 PM
