JDM cluster?????????please help!!!!!!!!
WASSUP PEOPLE I WAS JUST WONDERING I WANT TO GET THE JDM CLUSTER WITH 9000 RPM ON IT . BUT I WANTED TO DOUBLE CHECK AND SEE IF SOME PEOPLE HAVE IT IN THERE CAR AND IF EVERYTHING IS WORKING. I WANT TO KNOW IF U NEED A ELECTRONIC VSS AND IF EVERYTHING ELSE PLUGS RIGHT IN
IF U COULD ALSO CAN U PROVIDE A PIC OF UR CLUSTER
NEED HELP ASAP
THANXS
Modified by all_motoref9 at 9:41 PM 1/12/2004
NEED HELP ASAP
THANXS
and do a search b/c i know for a fact you will find more info than you need
edit:
i did a search for ya, should be plenty of info here: https://honda-tech.com/zerothread?id=683164
edit:
Here is a link to a write up of how to install the EF8 JDM cluster.
http://b16a.honda-perf.org/cluster.html
If you are looking for a tach with 9k Rpms why not try a 99-00 civic Si cluster. Here is a link to my write up.
https://honda-tech.com/zerothread?id=709958
Also yo umay want ot edit your post with the caps off
-James-
-James-
B16Blake
Nov 13, 2009 11:47 PM
LSVTEC96HB
Sep 3, 2003 04:24 PM
Charlie Moua
Jul 26, 2002 06:59 PM
