What does the AC plug at the front of the GSR motor do???
Old Jan 2, 2004 | 03:48 PM
Red D Dragon's Avatar
Default What does the AC plug at the front of the GSR motor do???
Well when i got my gsr motor it had a cable that i could run an extension to and it plugs into the front of the block. I assumed it was an oil warmer for cold start ups. But no one has ever talked about it. I just assume its because the cable got lost right away. Can anyone explain what it is used for and how they use it?
Old Jan 2, 2004 | 05:44 PM
non-VTEC's Avatar
Default Re: What does the AC plug at the front of the GSR motor do??? (Red D Dragon)
its called a block heater.
warms up the engine coolant if you live in colder climates. works great in the freezing cold winters
Old Jan 2, 2004 | 09:24 PM
Does anyone use it and how long do you have it connected?
Old Jan 2, 2004 | 10:26 PM
boostn420's Avatar
Default Re: (Red D Dragon)
Its only there to prevent the water in the block from freezing and cracking the engine, that would suck. I live in SoCa so i dont know anyone that uses it I've only seen it a few times. Usually you just plug them in overnight until your gonna use your car again. If it isnt below freezing temps then I wouldnt bother with it.
Old Jan 3, 2004 | 09:40 AM
thanks. Ya I was just wondering if i should even bother using it. Like if would help reduce wear on start up or anything but i guess its not that cold up here in wisconsin. haha at least not yet :s
Corksil
10
Jun 10, 2010 03:28 PM
petwhookie
16
Jul 26, 2009 08:33 PM
TypeSLO
Jul 22, 2006 07:50 AM
Paprika
Dec 10, 2004 10:24 PM
