need help hooking up a auto meter
I have a auto meter vac and a air/fuel ratio. On the vac it has a black and white wire and a air line ,and the air/fuel, it has a red,black and purple wire. I need help on this . Thank
ok if you dont know where a to get vacum or where your O2 sensor is then.. RTFM!!!
(Thats read the fine manual FYI, god made manuals for a reason
werd.. if you don't know how to hook them up your obviously don't need them
black is always ground.. white and red a usually positive. the purple is the read wire on the o2 sensor..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civc 91 »</TD></TR><TR><TD CLASS="quote">I have a auto meter vac and a air/fuel ratio. On the vac it has a black and white wire and a air line ,and the air/fuel, it has a red,black and purple wire. I need help on this . Thank</TD></TR></TABLE>
I can't help you with the A/F gauge, but maybe I can give you some tips about the pressure gauge. As you can probably see, the black and white wiring is hooked up to the light bulb in the gauge. The black wire is a ground wire, so run it to a good grounding point either in the passenger compartment or run it to the engine bay.
For the white wire, run it to a light source that comes on when you turn on your parkinglight/headlight switch. In my old car (wasnt a Honda) I spliced into the wiring for my coin holder light bulb. I just snipped the positive wire leading to the light bulb, and wired in the white wire for the autometer gauge and crimped it all together with a butt connector. This was kinda ghetto, but it worked.
For the vacuum/boost source you can use a nipple on the intake manifold. I am assuming you have a length of small diameter nylon hardline. You will have to get the appropriate size barb connector to connect to the end of the autometer adapter. Then you hook up a vacuum line from the barbed end to the nipple on the intake manifold.
Here is whatyour typical vacuum hookup should look like (FYI that is not a Honda in the pic) :
The big brass barb fitting on the end (with all the white teflon) is the only thing that was not included in the autometer kit. Then I just get a length of vacuum line (5/8") and ran it to a nipple on the IM. just to be safe I used some tiny hoseclaps on the IM nipple and also on the fiting barb end.
shorejdm5
14
Dec 29, 2007 01:51 PM
mortificationrock
Jun 4, 2007 08:16 PM
ShortbusEK
10
Aug 27, 2003 08:07 PM
