newbie alarm install question:where are the accessory and starter outputs?
I have a 94 civic Si and i'm installing a crimestoppercs-2013fm. The one with the 2 way remot start and alarm. Now I belive the black wire with the yellow strip is for the ignition but which ones do I use for the accessory & starter output. I do not have a meter to measure voltage with and no money to buy one so testing wires to find it is out of the question. So does anybody know which wires I can use?
12v-white
starter-Black/white
Ing-black/yellow
Ing 2-yellow
Acc-White/black or yellow
All of this are at the column
P/l-green/white
p/ul-Green/red
both are neg and can be found in driver kick or behind fuse box
Parking lights-red/black
This wire is positive can be foung in driver kick or at the switch
Tack-blue
important for remote start in 2pin conn near dist
Brack wire-green/white
Very important for R/S
This wire can be found at the top of brake pedal
hope this is what you are looking for
starter-Black/white
Ing-black/yellow
Ing 2-yellow
P/l-green/white
p/ul-Green/red
Tack-blue
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C70Civic »</TD></TR><TR><TD CLASS="quote">12v-white
starter-Black/white
Ing-black/yellow
Ing 2-yellow
P/l-green/white
p/ul-Green/red
Tack-blue
The only thing that confuses me is I didn't know there was an IGN 2 on my car. I thought that the ACC was yellow, but you say the IGN 2 is yellow and the ACC may be yellow as well. Very confusing because I don't know if I should hook up the option IGN2 on my alarm to the car.
starter-Black/white
Ing-black/yellow
Ing 2-yellow
P/l-green/white
p/ul-Green/red
Tack-blue
One question? is there the black white, I havent done that style civic in a long time
If it is and there are 2 inj wires for the remote start then do this
use the yellow as the inj 2 and the black white as acc
you should fire up the inj 2 for the remote start
because both the pink/white and pink (ON DEI ALARMS Im not sure what the inj colors on crime stoppers are) on the remote start need to be in use
the yellow can be used as an acc but i will turn the radio on
not the heater blower. programs I use are very accurate, thats where i got the info from. I hope this makes more sense and helps you out. any other questions please ask
