leaking oil near distributor
hi,
i got an accord and del sol...both cars seem to have oil near the valvecover front left corner near the distributor....
is it my valvecover gasket or something else????
It definitely could be the valve cover gasket. Pull it off and check it. I would also apply some Hondabond to that area when you put it back on. I don't think this is caused my the infamous B series cam seal leak.
It's a Del Sol and Accord. Now maybe if it is a B16a3 Del Sol, but the Golden Eagle stuff is only for B series motors. Those cars probably have a SOHC F series and a SOHC D series. I still say valve cover gasket or bad sealing distributor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PearlWhiteAccord »</TD></TR><TR><TD CLASS="quote">it is d16z6 with a new distributor...
so, how would i know if cam seal or gasket??
how much tq for the valve cover bolts??</TD></TR></TABLE>
you don't have a cam seal on that engine.
More than likely it's your distributor o-ring or the valve cover gasket. If you can't see it leaking where the VC meets the head, count that out. There are 3 12mm bolts to pull the distributor off. Before doing so, mark where the dist lines up unless you have a timing light.
When you pull it out, you will see a rubber o-ring where it slides into the head. Check for cracks, breaks, etc. You can get a new one at Honda, or at Home Depot for even cheaper
If they are SOHC its one of four things:
-Dizzy O-ring
-Valve Cover Gasket
-Head Gasket
-VTEC Solenoid Gasket (for VTEC models)
SOHC's don't have cam seals on the left side I dont know why everyone is saying that
-Dizzy O-ring
-Valve Cover Gasket
-Head Gasket
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">If they are SOHC its one of four things:
-Dizzy O-ring
-Valve Cover Gasket
-Head Gasket
becuse they ride the short bus
and I highly doubt it's the head gasket. I personally have never seen a good running car leaking oil out of the head gasket.
-Dizzy O-ring
-Valve Cover Gasket
-Head Gasket
</TD></TR></TABLE>becuse they ride the short bus
