Is the ITR fuel tank capacity 13.2 gallons ??
Fuel Tank Approximately 13.2 U.S. gallons (50 liters) ... http://69.53.28.141/specifications.html#fuel
My manual states 50 liters or 13 gallon capacity. Warning ligth comes on with 8 liters left. That's approx. 2 gallons.
This is assuming a US gallon is 3,85 liter, am I correct?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by opie112 »</TD></TR><TR><TD CLASS="quote">My light never comes on no matter how low my needle gets on the guage
Definately not a good thing. Check the bulb and then if it still doesn't work then there might be something wrong with the sensor.
</TD></TR></TABLE>Definately not a good thing. Check the bulb and then if it still doesn't work then there might be something wrong with the sensor.
Have you ever run out of gas yet?
</TD></TR></TABLE>Have you ever run out of gas yet?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99ITR#3715 »</TD></TR><TR><TD CLASS="quote">My manual states 50 liters or 13 gallon capacity. Warning ligth comes on with 8 liters left. That's approx. 2 gallons.
This is assuming a US gallon is 3,85 liter, am I correct?</TD></TR></TABLE> thats what i read yesterday on car and driver 13 gallon tank
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zygspeed »</TD></TR><TR><TD CLASS="quote">
I have. It's definitely 13.2 gallons and the light comes on with 3 gallons left. You also have the gas that fills the lines and you can top it off, as I have squeezed 13.5 in before.
</TD></TR></TABLE>I have. It's definitely 13.2 gallons and the light comes on with 3 gallons left. You also have the gas that fills the lines and you can top it off, as I have squeezed 13.5 in before.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoCal ITR »</TD></TR><TR><TD CLASS="quote">
I have. It's definitely 13.2 gallons and the light comes on with 3 gallons left. You also have the gas that fills the lines and you can top it off, as I have squeezed 13.5 in before.</TD></TR></TABLE>
was that when we went to hooters? when you ran out of gas and had already used your backup tank
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JLB SMZ »</TD></TR><TR><TD CLASS="quote">
Nope...
That was another time..
</TD></TR></TABLE>Nope...
drrep
Jun 1, 2004 03:11 AM
