pm6 chip problem after install ????
Old Jan 2, 2004 | 07:26 AM
vtecef9's Avatar
Default pm6 chip problem after install ????
anyone put a "power chip " purchased on ebay on a pm6 ecu? after the installation the car star but on the idle after 1 or 2 minute the idle raise to 1500rpm the engine have big hesitation and i have a check engine code 1 wtf?? if i run with the car all is ok its only on the idle......is it the chip or the installation?
Old Jan 2, 2004 | 07:43 AM
vtecef9's Avatar
Default Re: pm6 chip problem after install ???? (vtecef9)
do i need to put a jumper like when i chipped my pr3 ??? i use this ecu to run a sohc zc . please anyone!!
Old Jan 2, 2004 | 07:59 AM
USDM 4G VTEC's Avatar
code 1 is a O2 sensor
reset the ecu
make sure is not there
to make sureis not ur sensor try a stock ecu or put the stock chip on the ecu again fi u have the quick snap in and out socket
Old Jan 2, 2004 | 09:58 AM
vtecef9's Avatar
Default Re: pm6 chip problem after install ???? (USDM 4G VTEC)
the code 1 does not flash the led stay always open and
yes i have try the chip on the socket and all is fine its only when i put the reprogramed chip
Old Jan 2, 2004 | 11:55 AM
vtecef9's Avatar
its really when i drop the rpm under 2000rpm (during a couple of seconds)that the cel comes on (the light does not blink but stay open) and i can hear the main relay click at the same time and after that i have no more power and i need to restart the engine everytime. if the rpm stay up to 2000rpm all is ok EVERYONE PLEASE I NEED HELP !!!!!!!!!!!
egbaby
Mar 7, 2008 11:23 AM
hawaiianhana
Sep 21, 2007 03:10 PM
EK k kay
Jul 8, 2006 08:28 PM
ICEMAN707
12
Jul 2, 2006 03:45 PM
CRXb18Turbo
Oct 20, 2005 05:48 PM
