dpfi -> mpfi swap - 1988 si vacuum lines question
Old Jan 2, 2004 | 07:21 AM
tilt's Avatar
Default dpfi -> mpfi swap - 1988 si vacuum lines question
From what I gather, the 1988 crx si intake manifold runs its vacuum lines differently than other crx si models. The 88 si model has 2 vacuum connections on the dashpot thing (one pointing towards the passenger side and the other pointing towards the driver side).
Basically I have 2 vacuum hoses coming off the firewall, but there are 3 connections on the intake manifold.
For those that have done the mpfi conversion using the 88si manifold, how did you run the vacuum lines? thanks
Old Jan 2, 2004 | 10:59 AM
tilt's Avatar
Default Re: dpfi -> mpfi swap - 1988 si vacuum lines question (tilt)
Old Jan 2, 2004 | 12:01 PM
tilt's Avatar
well i just plugged up the T fitting between the intake manifold and dashpot. seems to idle fine.
I am throwing code 20 however. Electric Load Detector... Does anyone know what I need to do to fix this?
Old Jan 2, 2004 | 02:54 PM
tilt's Avatar
Fixed it. If anyone wanted to know the eld thing was bad. https://honda-tech.com/zerothread?id=468260
swaped out the fuse box under the hood and no more code.
classciv
11
May 9, 2007 03:51 PM
rice a roni
Oct 20, 2006 08:48 AM
Project_ED8
Mar 7, 2004 10:16 AM
YumVTEC
Mar 21, 2003 11:01 PM
