Another eg rad mounting question...
Old Jan 2, 2004 | 06:34 AM
sCeRaXn's Avatar
Honda-Tech Double Platinum Member
Default Another eg rad mounting question...
I ordered my koyo radiator for the eg and a jimfab xmember back in november...but after working on my car everyday for like 6 straight months i decided i wasnt going to touch my car again until after the new year. So here it is...the 2nd day of 04 and ive already got the itch to work on it. Anyway, my real question is what should i use for lower mounts for my eg radiator? I was thinking that i might make some and mount it to the xmember...but im scared i mihgt hit something and break the mount off. What did you ef pimps do? Pics would be nice too.
PS-its a 90 crx with a b18a, hasport mounts, t3/t04e...blah blah blah you get the point
Sean
Old Jan 2, 2004 | 07:18 AM
dingusjt's Avatar
Default Re: Another eg rad mounting question... (sCeRaXn)
you shouldn't have any problem with putting the mounts on the x member at all thats exactly how place racing does theirs....however you might run into a probably with your original radiator mount tabs getting in the way.
Old Jan 2, 2004 | 09:13 AM
sCeRaXn's Avatar
Default Re: Another eg rad mounting question... (dingusjt)
So if i cut off my stock rad mounts and make new ones for the xmember than i should be fine? How should i make the mounts for the xmember? Thanks
sean
Old Jan 2, 2004 | 10:10 AM
dingusjt's Avatar
hmmm thats a good questions...basically on my place racing x member its just 2 holes which the radiator pegs drop into.
after cutting you stock rad mounts you cold also easily bolt/weld some bent metals strips to hand further down and serve as your new mounts.
1____
sort of like that, attached to the undersid of your frams and hanging down with holes drilled for the radiator to drop in.
Old Jan 2, 2004 | 12:53 PM
sCeRaXn's Avatar
Yea thats exactly how i was thinking about doing it...thanks man. Anybody know what hoses im gonna need right off the top of their head? Prolly teg ones but im not sure.
Sean
Old Jan 3, 2004 | 07:29 AM
dingusjt's Avatar
you mean for the radiator hoses??? my stock hoses fit just fine...you may have to trim the upper hose cause it seems a little too long but i didn't and i don't seem to have any problems.
caraudiowiz
Nov 17, 2014 08:44 PM
ivan93egreppin210
Dec 14, 2008 04:27 PM
inh
Nov 11, 2007 12:47 AM
HondaFanatic708
Apr 5, 2005 07:36 PM
Jonathan_ED3
Apr 5, 2003 07:49 PM
