How much nitrous can i use on my new setup?
Old Jan 1, 2004 | 08:12 PM
nitrous chic's Avatar
Default How much nitrous can i use on my new setup?
as the topic says.
here is my setup-
ls/vtec
the bottom end consists of, block guard, je 12.5 pistons, eagle rods, and head studs.
the head has type r springs retainers and cams. jg intake manifold and 70mm TB. and a custom header.
the car also has hondata s100.
Old Jan 1, 2004 | 08:17 PM
Suprdave's Avatar
Default Re: How much nitrous can i use on my new setup? (nitrous chic)
I'm thinking start with a fitty shot and work up...
Skip01's Avatar
Thats some high comp. ,i'd say like 75shot.
Looks like your going for an all-motor setup.
Old Jan 1, 2004 | 08:19 PM
Default Re: How much nitrous can i use on my new setup? (Skip01)
thats it? 50 or a 75 shot, i was thinking like a 100 to 150.
Old Jan 1, 2004 | 08:25 PM
Suprdave's Avatar
With a 150shot, I would build a seperate fuel system for the naws...thats just me tho...Im a big *****.
Old Jan 1, 2004 | 08:34 PM
miller's Avatar
Default Re: How much nitrous can i use on my new setup? (Suprdave)
race gas and a seperate map in the hondata and you will be able to run the 150 shot.
Old Jan 1, 2004 | 11:24 PM
agrn93ls's Avatar
i have a 95 gsr with 140K miles, im using the NOS plate kit which is the closest to direct port without actually being direct port. its a wet shot, im running i guess you would say about a 60 shot, mix and matched jets tuning on the dyno and it made 64 more hp and 82 more ft lb's at 1100 psi bottle press so at the normal pressure of about 950 psi it should be about a 60 shot. but anyways point is im making 217hp and 197ft lb's torque, stock block, and it is damn fast i wax LS1's so id say that is fast enough. dont try to start of with a huge shot you need to learn how to use it first. start with like a 50 shot and bottle pressure is very important you want to run at least 950lbs. i love to hit it at 1100lbs. cant hook up in first or second on street tires. with the power im making it should be capable of low 13's possibly better. i started out on a 40 shot and on real low bottle pressure, like 850lbs i ran a 14.2 on nitto drags but didnt even heat em up so capable of lot better with better launch
Old Jan 1, 2004 | 11:48 PM
Erik_Pb_Foot's Avatar
New User
Default Re: How much nitrous can i use on my new setup? (agrn93ls)
he said "naws" i thought we were talkin about nitrous here? hehe
i'd say a direct port 100-150 shot with race fuel and big slicks...
-Erik
1 Cam Wonder
Nov 26, 2004 11:30 AM
scUba-stEve
14
Oct 14, 2004 10:17 AM
2008cc
Mar 14, 2003 06:37 PM
zilverz
Oct 28, 2002 12:06 PM
