Brake Lamp?
Old Jan 1, 2004 | 07:49 PM
J's 94 Accord's Avatar
Default Brake Lamp?
Ok, my girlfriend's car is a bit weird. One of her brake light bulbs are brighter than the other. We are just going to change both bulbs, but the "BRAKE" Lamp in the cluster is always on no matter what.
Any help would be great for me and her. Thanks
Old Jan 2, 2004 | 07:05 AM
1994AccordSiR's Avatar
Default Re: Brake Lamp? (J's 94 Accord)
that is the parking brake light not the tail light brake light, or at least thats how it works in my 94
Old Jan 2, 2004 | 09:30 AM
.bagged's Avatar
Check the fluid too...
Old Jan 2, 2004 | 06:30 PM
mwkirchner's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J's 94 Accord &raquo;</TD></TR><TR><TD CLASS="quote">Ok, my girlfriend's car is a bit weird. One of her brake light bulbs are brighter than the other. We are just going to change both bulbs, but the "BRAKE" Lamp in the cluster is always on no matter what.
Any help would be great for me and her. Thanks</TD></TR></TABLE>
Your problem is a ground issue. Somewhere in the circuit there is a ground that is not grounding fully. You will have to get a schematic to follow the circuit. When you find the grounding points ... you should undo the bolt and sand the area beneath when the bolt goes through the connector to help it ground better.
Old Jan 2, 2004 | 06:32 PM
The_Todd's Avatar
Farts in the shower
Default Re: Brake Lamp? (bagged93accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bagged93accord &raquo;</TD></TR><TR><TD CLASS="quote">Check the fluid too...</TD></TR></TABLE>
True and check your brakes...usually its a sign of wear on the brake system, if you have no lights out, its probably your brakes and not just your lamps
Old Jan 2, 2004 | 06:40 PM
mwkirchner's Avatar
The brake light indicator works on a grounding system to let you know when a bulb is out. If he has one bulb that is brighter then another ... then it is sending a signal that a grounding problem exists and that is why the light is on.
Yes ... it can also indicate that your brakes are getting low ... but considering what he has said in the thread ... it is gonna be because of the ground problem he is experiencing.
Old Jan 2, 2004 | 09:32 PM
Default Re: (mwkirchner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mwkirchner &raquo;</TD></TR><TR><TD CLASS="quote">The brake light indicator works on a grounding system to let you know when a bulb is out. If he has one bulb that is brighter then another ... then it is sending a signal that a grounding problem exists and that is why the light is on.
Yes ... it can also indicate that your brakes are getting low ... but considering what he has said in the thread ... it is gonna be because of the ground problem he is experiencing.</TD></TR></TABLE>
That was the exact problem. I spent 15 mins figuring it out and one of the rear brake lights were brigther than the other. So it was caused by grounding. One of teh sockets were dented so the bulbs werent completely "closed"
Thanks for all the help
SCinCA
Oct 6, 2014 06:35 PM
professorman
Oct 27, 2013 06:28 AM
rleonekc
Mar 26, 2006 06:56 AM
EuRoBrO
Dec 1, 2003 01:32 PM
civicboisi
Mar 8, 2003 06:45 AM
