NOLOGY Wires
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KGAccord »</TD></TR><TR><TD CLASS="quote">no it's a scam. plugs and wires do not give you hp, unless your car current ones are worn out or if your running crappy platinum plugs or cheap autozone wires.</TD></TR></TABLE>
yup what he said!!!
yup what he said!!!
if you want show then just get some NGK blue wires, and not sacrafice the way your car runs holmes.
Other than NGK plugs and wires the car wont make any power with plugs and wires unlesss your making wayyyyy too much power for an accord
NGK=OEM for honda....so obviously they did their homework, mainly its for show or unless you have upgrades (turbo ignition etc) that would require more spark...other than that keep it oem and save the dough.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by streetrays »</TD></TR><TR><TD CLASS="quote">you might see little gain on top end, given that you're making over 250whp..
just like the ground wire gain.. a little on top for higher hp cars..</TD></TR></TABLE>
Your stock 140ish hp won't need that.....IMO stock stuff is good....save for some goodies because those wires/plugs can cost a decent amount of $$, I would much rather spend it on sway bars or shocks or h22 swap or....the list is long, down the road I would swap them out.
Got Spoool
26
Jun 13, 2003 03:06 PM
