E-Break light wont go off
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY »</TD></TR><TR><TD CLASS="quote">Check your brake fluid. TOP IT OFF
2nd that...
</TD></TR></TABLE>2nd that...
WTF man?.. ever car has a break fuild resevior.. thats like a car without a gas tank?.. and umm the motor has nothing to do with.. you eirther need to top off your break fuild or check the connections at the e break
Guest
Posts: n/a
ok, i was just making sure man. calm down <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JonGP4 »</TD></TR><TR><TD CLASS="quote">WTF man?.. ever car has a break fuild resevior.. thats like a car without a gas tank?.. and umm the motor has nothing to do with.. you eirther need to top off your break fuild or check the connections at the e break</TD></TR></TABLE>
For the light to come on you either have:
1. A leak
2. Worn out pads
"Topping it off" isn't the answer to either of them. (Maybe temporarily)
Either find the leak and fix it
or
install new pads/shoes
(When you install new pads/shoes after "topping it off" you're going to be pushing the "extra" brake fluid out of the master cylinder, very messy)
1. A leak
2. Worn out pads
or
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 7PSI CRX »</TD></TR><TR><TD CLASS="quote">For the light to come on you either have:
Or you could bleed the breaks while you are at it, like its recommended to do
I concur with what he says,....the only other possibility is that the switch for your ebrake is shorted on....but I'd worry about your brakes first.
</TD></TR></TABLE>Or you could bleed the breaks while you are at it, like its recommended to do
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jet Black »</TD></TR><TR><TD CLASS="quote">
I concur with what he says,....the only other possibility is that the switch for your ebrake is shorted on....but I'd worry about your brakes first.</TD></TR></TABLE>Brakes. b-r-a-k-e-s.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jet Black »</TD></TR><TR><TD CLASS="quote">Oh gimme a brake
</TD></TR></TABLE>Sorry. It irks me.
Yeah Don't remove your Resevoir Cap . Just open the bleeder valve on your caliper and press in the piston. Then top off you resevoir. The dirtiest brake fluid will settle near your caliper in the lines. If you just remove the cap and compress your caliper piston you will push all that **** right into your MC.
Good call Jet Black
Good call Jet Black
1. A leak
2. Worn out pads
Or the fluid just got a little to low because some evaporated.
1. A leak
2. Worn out pads
lowRIDAH
11
Jul 22, 2005 01:37 AM
philosofy1
Apr 25, 2005 11:39 AM
