does a fuel pressure regulater increase hp??
Old Jan 1, 2004 | 04:56 PM
Fraggle's Avatar
Default does a fuel pressure regulater increase hp??
or is it just for boosted applications or to corect a too rich or lean problem??
Old Jan 1, 2004 | 04:57 PM
Jonathan_ED3's Avatar
it's for any application to correct a rich or lean problem.
Old Jan 1, 2004 | 05:00 PM
Fraggle's Avatar
Default Re: does a fuel pressure regulater increase hp?? (Fraggle)
but if i dont have a rich or lean prob, should i just not bother with it??
jdmsiR20's Avatar
Default Re: (Jonathan_EH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonathan_EH &raquo;</TD></TR><TR><TD CLASS="quote">it's for any application to correct a rich or lean problem.</TD></TR></TABLE>
can it be used to increase performance, or just attain the 'correct' air/fuel mixture?
Old Jan 1, 2004 | 05:03 PM
Fraggle's Avatar
Default Re: (jdmsiR20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmsiR20 &raquo;</TD></TR><TR><TD CLASS="quote">
can it be used to increase performance, or just attain the 'correct' air/fuel mixture?</TD></TR></TABLE>
exactly what i was tryin to say, just dont gotta good ejumicashun
Old Jan 1, 2004 | 05:06 PM
By tuning the regulator and getting an optimal air/fuel mixture you can acquire a few HP. But like I said, unless you already have a problem, it's not going to be of any benefit.
EDIT: It's just a tool....like any tool, you have to actually use it. You can't just slap it on and expect it to do anything.
Old Jan 1, 2004 | 05:11 PM
Fraggle's Avatar
so would my i/h/e affect my mixture or not really, other than that i have msd, but nothin major (yet )
elevatethis's Avatar
My butt dyno says that my top end pulls slightly better with the fuel pressure dialed at 45psi @ idle. Again, the butt dyno says that.
Old Jan 1, 2004 | 05:13 PM
Ricey McRicerton's Avatar
Default Re: (elevatethis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elevatethis &raquo;</TD></TR><TR><TD CLASS="quote">My butt dyno says that my top end pulls slightly better with the fuel pressure dialed at 45psi @ idle. Again, the butt dyno says that.</TD></TR></TABLE>
placebo effect man. Honestly, a FPR does jack **** but change rich/lean conidtions.
Old Jan 1, 2004 | 05:14 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fraggle &raquo;</TD></TR><TR><TD CLASS="quote">so would my i/h/e affect my mixture or not really, other than that i have msd, but nothin major (yet )</TD></TR></TABLE>
If it was my car, I'd go ahead and put one on. It's a mod you can build around, and it will ALWAYS be beneficial for tuning!
Old Jan 1, 2004 | 06:22 PM
JSPECHB's Avatar
Default Re: does a fuel pressure regulater increase hp?? (Jonathan_EH)
It regulates fuel pressure.
Old Jan 1, 2004 | 08:05 PM
Skip01's Avatar
I agree,its a good investment for the future.When I put in my fuel pump,I felt a little better top-end,not much just pulled a little smoother.
Old Jan 1, 2004 | 09:03 PM
Default Re: (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">
placebo effect man. Honestly, a FPR does jack **** but change rich/lean conidtions.</TD></TR></TABLE>
Agreed
maxamusprime
Jan 21, 2007 02:30 PM
ALMXDUPINTEGRA
Aug 30, 2005 05:21 AM
deesh123
11
Dec 4, 2003 04:28 PM
ddua
Oct 4, 2003 10:08 AM
vtec_yosh
Sep 25, 2003 01:26 PM
