where is my fuel pump electrical connector?
Old Sep 25, 2001 | 05:13 PM
clean's Avatar
New User
Default where is my fuel pump electrical connector?
it's on my 97 ex, trying to change the pump tonight
Old Sep 26, 2001 | 05:08 AM
BakedCookies's Avatar
Default Re: where is my fuel pump electrical connector? (clean)
under the rear seat, in the center there is an aluminum cover, remove it, you will see the harness and fuel send and return lines there for the pump. make sure to depressurize the fuel line at the fuel filter in the engine bay, then unplug connnections and undo the 7-10 10mm bolts and pull out, it will be full of fuel still so dont go slinging it around your enterior. hope this helps...
Old Sep 26, 2001 | 11:15 AM
Ubermensch's Avatar
Default Re: where is my fuel pump electrical connector? (BakedCookies)
^exactly right^
o2flow.net
Oct 1, 2006 08:55 AM
inhms
Jul 4, 2006 01:40 PM
SpoonyGSR
Mar 22, 2004 02:11 PM
