putting CTR sway bars on a CX
Old Jan 1, 2004 | 07:24 AM
Mr. 1582's Avatar
Default putting CTR sway bars on a CX
Could this idea work. If I get the mounting hardware from suspention tech. and buy CTR sway bars and put them on. Is this possible.
Old Jan 1, 2004 | 08:47 AM
navin's Avatar
Default Re: putting CTR sway bars on a CX (Mr. 1582)
front - you probably need the LCA's, endlinks, etc..
rear - you can get the ITR [i think same size] and use a beaks reinforcement kit..
Old Jan 1, 2004 | 01:50 PM
Mr. 1582's Avatar
Default Re: putting CTR sway bars on a CX (navin)
What the size are the sway bars on a Civic type R and a Integra type R.
Old Jan 1, 2004 | 01:53 PM
spnfed's Avatar
I beleive the CTR is 22mm for the rear bar.
Old Jan 1, 2004 | 02:08 PM
Mr. 1582's Avatar
Default Re: (spnfed)
What about the front.
Old Jan 1, 2004 | 02:43 PM
spnfed's Avatar
The front CTR is 26mm.
Old Jan 1, 2004 | 03:02 PM
locass316's Avatar
front ctr and si should be the same
Old Jan 1, 2004 | 07:17 PM
frankdatank's Avatar
Default Re: (locass316)
i put a si front sway bar on my hatch, you need the lower control arms and the forks also
Old Jan 1, 2004 | 07:53 PM
flat-blk-HB's Avatar
Default Re: (frankdatank)
I got 95 LS integra front and pencil rear on my 92 CX..I used the all the hardware and endlinks from the donor car. you need the LCA's from both front and rear.
And frankdatank...Dave Chapelle is pretty damn funny....
Old Jan 1, 2004 | 08:53 PM
spnfed's Avatar
You don't need the rear lower control arms just the fronts. Just go to Honda and get the end links and mounting hardware for the rear bar, I don't think the suspension tech will work.
ZombiePharoh
Suspension & Brakes
Feb 23, 2014 08:36 PM
klomast3r
Nov 5, 2005 04:08 PM
VSMHatcH
Aug 29, 2004 10:52 AM
seek167
Mar 11, 2003 03:48 AM
HKxBlur
Feb 3, 2002 10:21 PM
