what do you'll do to provide a positive airflow throw your crankcase
Old Jan 1, 2004 | 07:16 AM
Prelude91siT's Avatar
Default what do you'll do to provide a positive airflow throw your crankcase
i was wondering cause i read that those lil breather filters r bull ****. i read u need a positive airflow for your pcv to work properly. i was wondering would did u turbo guys did about this. or r u just running the breather filter
Old Jan 1, 2004 | 09:08 AM
scttydb411's Avatar
Default Re: what do you'll do to provide a positive airflow throw your crankcase (Prelude91siT)
i just ran a breather filter. you can run a line from the valvecover back to the intake tube BEFORE the turbo. this just reroutes any valve cover gases back into the intake track to be reburned.
Old Jan 1, 2004 | 10:28 AM
mrctr's Avatar
Default Re: what do you'll do to provide a positive airflow throw your crankcase (scttydb411)
So if you route a hose from the valve cover to a spot near the airfilter i know you'd have to drill a hole for the hose, but shouldn't you need a catch can in between the hose somewhere?
I already have catch can in between my pcv valve and i'd like to run a hose from my valve cover to a spot somewhere near the airfilter instead of just putting a little air filter on my valvecover.
Old Jan 1, 2004 | 10:42 AM
kid-honda's Avatar
Their is nothing wrong with the little filters and if you do a search somebody did a huge write up with testing to show how they do not affect anything for the worse.
fryman
Apr 3, 2013 04:12 AM
digital sol
Aug 22, 2005 09:47 PM
redtegger03
Jun 25, 2003 10:41 AM
1.8T_EG
Aug 13, 2002 01:21 PM
