86mm?
Old Dec 31, 2003 | 10:21 PM
jaydmcrx's Avatar
Default 86mm?
Would you guys go 86mm 12.5:1 compression in my ls vtec??? GE sleeves. I was told by someone that it isnt very reliable?? But i dont see how?
Old Jan 1, 2004 | 03:46 AM
00 FBP ItR's Avatar
Default Re: 86mm? (jaydmcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaydmcrx &raquo;</TD></TR><TR><TD CLASS="quote">Would you guys go 86mm 12.5:1 compression in my ls vtec??? GE sleeves. I was told by someone that it isnt very reliable?? But i dont see how?</TD></TR></TABLE>
If you have the money, If you don't mind rebuilding your motor every 6mo-1yr.
Its not reliable b/c 86mm is very thin, and between cyl 1/2/3/4... the cyl walls will be thin, and it'll start to "oval".
Street motor.. 84.5mm w/ 89mm crank
Old Jan 1, 2004 | 06:22 AM
Stunna BEN's Avatar
Don't call it a comeback
Default Re: 86mm? (00 FBP ItR)
I think there would also be cooling or temp issues as well, for a full street car. Sitting at idle and more, this would be tough on that bore.
Old Jan 1, 2004 | 12:57 PM
runwhatubrung's Avatar
Default Re: 86mm? (-BEN-)
if ya do it let us know how it goes
Old Jan 1, 2004 | 03:09 PM
jaydmcrx's Avatar
what is the stock stroke on an ls crank. I could search it but im lazy. And if i use an 89mm crank do i have to deck the block then? Or can i just use the stock block and go with 84.5mm pistons and still get my displacement?
Old Jan 1, 2004 | 03:14 PM
kid-honda's Avatar
I remember a couple daily driven cars on here with 86mm.
Its not the best idea but it can be done.
The downfall to 86 is if you ever loose a ring at 86 mm you dont have much option aside from resleeving.
Old Jan 1, 2004 | 06:42 PM
jaydmcrx's Avatar
Yah i understand that. I think i might just go 85mm, and keep the stock stroke of the crank and everything. I dont think it will hurt me that bad.
Old Jan 2, 2004 | 12:31 AM
ExospeedAMcrx's Avatar
Default Re: (jaydmcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaydmcrx &raquo;</TD></TR><TR><TD CLASS="quote">Yah i understand that. I think i might just go 85mm, and keep the stock stroke of the crank and everything. I dont think it will hurt me that bad.</TD></TR></TABLE>
I'd even be more conservative and stay 84mm. just becuase it gives you more room to play with in case you want to rebuild later.
Old Jan 2, 2004 | 08:45 AM
jaydmcrx's Avatar
Well it is going to be mainly a race car. I have a buick for daily driving. But we will see. It is going to be street driven as well.
Old Jan 2, 2004 | 08:56 AM
Stunna BEN's Avatar
Default Re: (exospeedAMcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exospeedAMcrx &raquo;</TD></TR><TR><TD CLASS="quote">
I'd even be more conservative and stay 84mm. just becuase it gives you more room to play with in case you want to rebuild later.</TD></TR></TABLE>
The way i would go
Old Jan 2, 2004 | 09:35 AM
Suprdave's Avatar
You can order pistons that are .002 oversize.
How often does this car see the street? Daily Driver? 85mm...
Old Jan 2, 2004 | 09:36 AM
jaydmcrx's Avatar
it will see the street almost everyday in the summer. But in the winter not at all.
Old Jan 2, 2004 | 11:52 AM
Suprdave's Avatar
Build it for 85mm...only do 86 if your going all-out, and your obviously not.
Suprdave
Old Jan 2, 2004 | 01:44 PM
00 FBP ItR's Avatar
Default Re: (Suprdave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suprdave &raquo;</TD></TR><TR><TD CLASS="quote">Build it for 85mm...only do 86 if your going all-out, and your obviously not.
Suprdave</TD></TR></TABLE>
yup.... if you were going all out you wouldn't only be looking at the bore to get more displacement.
If you're going "all-out" you should go 86mm x 95mm that'll be about a 2.2L out of a b-series... Sounds great huh? but will not last long as a daily car.
I'd do 84/85, if you scar a sleeve you can always go bigger after. w/ 86.. you have not option but to resleeve.
Old Jan 2, 2004 | 06:14 PM
jaydmcrx's Avatar
Yah im not going to mess with the crank much. I was thinking a basic knife edge or something along those lines. I am just looking for a stront 230whp 12.0-11.9 sec. street car. My car weighs 1900lbs with me without the lexan yet. And some suspesion work and slicks are in the works too. Kind of going for that border line street car race car thing.
Old May 26, 2004 | 08:09 PM
krazie1's Avatar
BANNED
what if it was sleeved
and sort of build??
like ported head and h beam rod and acl bearings and balanced crank???
then what would u think for weekends and so what drag car
what compression also
would u guys suggest
Old May 26, 2004 | 08:43 PM
MAX_CFM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suprdave &raquo;</TD></TR><TR><TD CLASS="quote">You can order pistons that are .002 oversize.
How often does this car see the street? Daily Driver? 85mm...</TD></TR></TABLE>
but .002 will add about .010 to the ring gap
Kiddox
Nov 1, 2007 04:09 PM
ShawnR
10
Jan 8, 2006 08:04 PM
escape2me
May 18, 2005 03:56 PM
chihuahuamanx
Oct 31, 2004 09:50 AM
sloweredcivic
19
Oct 8, 2004 08:21 PM
