Skunk 2 stage 1 cams
Old Dec 31, 2003 | 10:01 PM
00EM1Si's Avatar
Default Skunk 2 stage 1 cams
I have Skunk 2 stage 1 cams on my b16a2...Did anyone have any problems with them with the O2 sensor? The check engine light goes off when Im crusing....It goes off at least once a day...I'm not sure what exact the code that came out but it was something about the o2 sensor. I restart my ecu to make the engine light shut off.... Is it the cams or the O2 sensor thats making the engine light go off? thanxs
Old Jan 1, 2004 | 05:39 PM
00EM1Si's Avatar
anyone?? TTT
Old Jan 3, 2004 | 06:16 PM
00EM1Si's Avatar
TTT
Old Jan 3, 2004 | 06:18 PM
JDM-97CX's Avatar
Default Re: Skunk 2 stage 1 cams (Krazipeenoi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Krazipeenoi &raquo;</TD></TR><TR><TD CLASS="quote">I have Skunk 2 stage 1 cams on my b16a2...Did anyone have any problems with them with the O2 sensor? The check engine light goes off when Im crusing....It goes off at least once a day...I'm not sure what exact the code that came out but it was something about the o2 sensor. I restart my ecu to make the engine light shut off.... Is it the cams or the O2 sensor thats making the engine light go off? thanxs</TD></TR></TABLE>
If the code is for your O2 sensor than the O2 sensor is what is making your CEL go off, not the cams. But it would help if you could post the exact code that it is throwing and then I could tell you for sure what the problem is.
Old Jan 4, 2004 | 05:26 PM
00EM1Si's Avatar
k thanxs
Old Jan 13, 2004 | 09:48 PM
00EM1Si's Avatar
Default Re: (Krazipeenoi)
K I Got the Code...Its P1457 ...and I have a 2000 Civic Si with a B16.....thanxs
Old Jan 14, 2004 | 12:38 AM
00EM1Si's Avatar
TTT
Old Jan 14, 2004 | 12:43 AM
Brandon EM1's Avatar
Is your gas cap tight?
Old Jan 14, 2004 | 12:44 AM
JDMlyfestyle's Avatar
Code P1457 Evaporative Emissions (EVAP) Control System Leakage (EVAP Canister System).... Theres your answer bro. for any other code ?'s just look at my ecu code list in my sig
Old Jan 14, 2004 | 09:03 PM
00EM1Si's Avatar
Default Re: (JDMlifestyle)
Thanxs....How do I fix the problem?
01SSAP1
Honda S2000
Sep 4, 2007 09:04 AM
civicsaremean
Jun 24, 2007 08:27 AM
the_0ne
Jul 16, 2006 08:01 PM
