tach install
Old Dec 31, 2003 | 05:29 PM
cpizzy's Avatar
Default tach install
I have 88 crx dx with zc dohc
i am installing a tachometer one of the ones with the shift light i picked up for a good deal. I am confused where to wire it up to.
I looked at the distrib and didnt know which wire to use and also what to use for the ignition wire and lighting wire.
pictures would be good
Old Dec 31, 2003 | 07:20 PM
SiB16A's Avatar
Default Re: tach install (cexodusk)
Blue Wire on the Dizzy on My caR (b18a1) it's like the Green wire from the tach to the blue. black is negative....white goes to like your lighter thing in your car or a head light/parking light fuse so you can turn it on and off when you turn on and off your headlights/parking lights/ and red it goes to a positive. and behind the tach cut the two wires that loops because you gotta 4 cylinder.
your tach if an AUTOMETER tach right? well if it's not then i dont know but the directions above are for autometers. Does anyone else have an easier way to hook a tach up?
Old Dec 31, 2003 | 07:38 PM
cpizzy's Avatar
what shold i hook the red wire to
Old Dec 31, 2003 | 07:43 PM
SOHC_Brian's Avatar
Default Re: tach install (SiB16a)
thats how i wire them up the rpm wire (blue) is in the two wire plug at the dizzy, not the 7 wire plug (just in case)
Old Dec 31, 2003 | 07:44 PM
SOHC_Brian's Avatar
red goes to a +12 volt, could tap it at the fuse box if you want
Old Dec 31, 2003 | 08:39 PM
ThatRicerDaniel's Avatar
search . been covered many times.
esean93
Aug 23, 2008 10:33 AM
pair8hd
Dec 1, 2007 03:44 PM
slimjimdanny
Jan 31, 2007 07:35 PM
bbhockey19
10
Jul 11, 2006 09:10 PM
FrOsTwHiTeDC4
Oct 11, 2005 06:12 PM
