tach install
I have 88 crx dx with zc dohc
i am installing a tachometer one of the ones with the shift light i picked up for a good deal. I am confused where to wire it up to.
I looked at the distrib and didnt know which wire to use and also what to use for the ignition wire and lighting wire.
pictures would be good
This is for an 89 HB, which should be the same for a rex.
http://www.wgn.net/~joe_r/tach/tachinst.html
Summary:
- Distributor wire goes to negative side of coil or blue wire behind dash
- Ground wire goes to any bolt that touches the frame or look for a bolt behind dash
Good to use lead tester from this point on.
- Lighting wire connects to a red with black strip wire or any wire that becomes "active" when headlights are on.
- Power wire connects to any wire that becomes "active" when key is turned to start position in the ignition.
Summary:
crx_ef8
Mar 10, 2003 10:47 PM
