Front wheel bearing replacement and wheel-stud install pictures/info (56K die)
Old Dec 31, 2003 | 04:25 PM
Willard's Avatar
Default Front wheel bearing replacement and wheel-stud install pictures/info (56K die)
"sorry charlie"
Modified by Willard at 11:21 AM 3/21/2007
Old Dec 31, 2003 | 04:34 PM
Smitdog's Avatar
Default Re: Front wheel bearing replacement and wheel-stud install pictures/info (Willard)
Great Write up and Pics Willard! You are Impressive as always! This is the Tech Information that h-t use to be flooded with back in the day......
ITR764's Avatar
nice write up d00de!!!
Old Dec 31, 2003 | 04:46 PM
Kicker773's Avatar
Default Re: Front wheel bearing replacement and wheel-stud install pictures/info (ITR764)
wow.. now if i only knew how to do that..
Old Dec 31, 2003 | 04:49 PM
myhatchrips's Avatar
you had to drill the hub? i have arps also and they just pressed in with no problems. make sure that those studs dont have any play. otherwise
Old Dec 31, 2003 | 05:01 PM
JjuuN R's Avatar
awsome write up~
Old Dec 31, 2003 | 05:02 PM
Willard's Avatar
Default Re: Front wheel bearing replacement and wheel-stud install pictures/info (myhatchrips)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by myhatchrips &raquo;</TD></TR><TR><TD CLASS="quote">i have arps also and they just pressed in with no problems. </TD></TR></TABLE>the first try at pushing the stud in was quite hard... after the drill out they were hard but not as hard.
don't worry.. there is no play at all.
Old Dec 31, 2003 | 05:46 PM
D's Avatar
D
Old Dec 31, 2003 | 06:06 PM
Dan GSR's Avatar
Default Re: Front wheel bearing replacement and wheel-stud install pictures/info (D)
awesome write up
saved it to my hard drive
Old Dec 31, 2003 | 06:27 PM
743power's Avatar
Default Re: Front wheel bearing replacement and wheel-stud install pictures/info (Dan GSR)
Good stuff Willard. I believe ARP makes a honda specific knurl size stud now, I have some on order, I will confirm when they come in. Anyway, I will be doing this to my civic in the next month or so, good write up.
Do I really need all of those sockets you listed? I can only imagine that those 2"+ ones are quite expensive at sears. Also, would you only recommend OEM Honda bearing as a replacement, or would a pepboys/autozone one be acceptable?
Old Dec 31, 2003 | 06:52 PM
type r 01-1063's Avatar
What kind of symptoms do you experience when you know the wheel bearings has to be replaced?
Old Dec 31, 2003 | 07:53 PM
Bbasso's Avatar
Allthough everything worked fine, I'm still scared about that press
Good detail and good pics!
Old Dec 31, 2003 | 08:05 PM
JjuuN R's Avatar
Default Re: Front wheel bearing replacement and wheel-stud install pictures/info (type r 01-1063)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by type r 01-1063 &raquo;</TD></TR><TR><TD CLASS="quote">What kind of symptoms do you experience when you know the wheel bearings has to be replaced?</TD></TR></TABLE>
1: noise from the area
2: jack the car up without it in gear and spin the wheel with your hand, if it don't look like it's moving freely enough check your brakes, then the bearing.
3: they're usually good for 100,000 miles+ if you're in a dry city.
i live in vegas where there's not too much rain or snow
Old Dec 31, 2003 | 10:10 PM
Nuts's Avatar
Default Re: Front wheel bearing replacement and wheel-stud install pictures/info (JUN.R)
nice write up..... looks like there are a lot of tools I am missing if I have to do it myself though.
Old Dec 31, 2003 | 10:36 PM
EK MONEY's Avatar
good write up
Old Dec 31, 2003 | 11:55 PM
Kicker773's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JUN.R &raquo;</TD></TR><TR><TD CLASS="quote">
i live in vegas where there's not too much rain or snow </TD></TR></TABLE>
hmm.. i live in the midwest area.. n well the car has been throug two snow seasons.. n i haven't checked on those.. but i did replace one of the axles.. hmm i wonder .. i'd have to check.. nice info on the symptoms
Old Jan 1, 2004 | 04:26 AM
Willard's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 743 &raquo;</TD></TR><TR><TD CLASS="quote">I believe ARP makes a honda specific knurl size stud now</TD></TR></TABLE>They do... but the GM ones were in stock and ~$11.50 for a pack of 5.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 743 &raquo;</TD></TR><TR><TD CLASS="quote">Do I really need all of those sockets you listed?</TD></TR></TABLE>
You need those or the Honda specific pressing tools. The China brand sockets worked quite well and are much cheaper than the Honda press heads.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 743 &raquo;</TD></TR><TR><TD CLASS="quote">I can only imagine that those 2"+ ones are quite expensive at sears </TD></TR></TABLE>
Dad got that socket set at a tractor show for his 3/4" drive socket set a while back... they have seen more use on the press than anything. Who have ever seen a 2-3/4" nut?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 743 &raquo;</TD></TR><TR><TD CLASS="quote">would you only recommend OEM Honda bearing as a replacement</TD></TR></TABLE>
If you can find it cheaper somewhere else be my guest. I know the Honda one will work and will last about a year of HPDE driving for me... so Honda it will be. They are now considered a wear item on my car (like rotors/tires). At the first of the year... the car will get a new drivers side bearing and every other year the car will get a passengers side bearing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by type r 01-1063 &raquo;</TD></TR><TR><TD CLASS="quote">What kind of symptoms do you experience when you know the wheel bearings has to be replaced? </TD></TR></TABLE>
Clicking when going over speed bumps while turning. Under normal use they should last well over 150,000 miles... but track use/heat shorten the life quite a bit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">I'm still scared about that press </TD></TR></TABLE>
The press is your friend.
Dad got it at a state auction a few years back for a $100 or so. It has paid for it's self many times over.
-re-bushed 3 Volvo's (full suspension)
-wheel bearing's
-Honda diff. bearing swap
Old Jan 1, 2004 | 07:27 AM
00MRSi's Avatar
Will, great writeup!! Thanks for sharing.
Old Jan 1, 2004 | 08:12 AM
rated_r's Avatar
love the wheel studs
Old Jan 1, 2004 | 08:23 AM
Philly_NBP_R's Avatar
Default Re: Front wheel bearing replacement and wheel-stud install pictures/info (rated_r)
sweet write up Willard!
I wish I had a press like that...
Old Jan 4, 2004 | 09:50 PM
mstewar's Avatar
nice write up, willard!
Old Jan 5, 2004 | 05:31 AM
Splat's Avatar
Collector-o-Guns and Drinker
FYI - Harbor Freight sells a 12-ton press for not a terrible amount of money. Willard can offer input on whether it would be hefty enough for this job, but I know it's more than enough for Volvo suspension bushings
Old Jan 5, 2004 | 05:40 AM
Willard's Avatar
Default Re: (Splat)
12T &lt; 28T
Old Jan 5, 2004 | 06:07 AM
Splat's Avatar
Default Re: (Willard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Willard &raquo;</TD></TR><TR><TD CLASS="quote">12T &lt; 28T </TD></TR></TABLE>
Well duh
But few have 28T presses in their garage
Harbor Freigh = economical alternative. Use it twice and it has paid for itself
Old Jan 5, 2004 | 06:44 AM
Johnny Tran's Avatar
Default Re: (Splat)
when are we bolting up the Weld Draglites and Sticky Mickey's ?
