Headers
Old Sep 25, 2001 | 02:00 PM
Another B16's Avatar
New User
Default Headers
What headers are being used on B16a in CRXs. Do the 4 to 1 headers cause clearence problems with the front cross-member?
Old Sep 25, 2001 | 03:11 PM
EVOCELICA's Avatar
New User
Default Re: Headers (Another B16)
I believe all 4- 1 headers cause problems with clearance, but it all depends on how you did your swap, if you cut and reweld your mounts you might be ok. If you use a mount kit just get the place race cross member it will free up enough space for the header.
Old Sep 26, 2001 | 12:30 PM
New User
Default Re: Headers (EVOCELICA)
How about application? Should I get one for a 94 Del Sol or some other application. How about type R headers?
Thanks
Old Sep 26, 2001 | 03:28 PM
akachef's Avatar
New User
you can fit a 4-1 on but you'll have to get the crossmember notched out a lot. i'd recommend taking the crossmember off and reinforcing it with some steel plates or something welded on, then notch it out. put a dc jdm 4-1 on my friends b16 in a crx. it's a nice header, good price, just had to get rid of a lot of **** in the way. any b16 fitment will work. dont for the type r, the sizing is bigger and will scrape more. that's something else to be concerned with, if your'e dumped, go for 4-2-1
Rev Red
23
Aug 22, 2007 11:09 AM
linkinparkfallower
29
May 3, 2006 12:57 PM
solo303
Dec 21, 2005 09:10 PM
ImportPower13
Jul 4, 2005 01:28 AM
CRX A4
12
Apr 3, 2003 09:19 AM
