Cluster Problem (already searched)
I searched for this but couldnt find any help.
Tonight my cluster lights just stopped working. I saw another post sayign check the reverse lights fuse, well I checked every fuse and none were blown. It worked earlier tonight, turned my lights on tonight and nothing. All the gauges are functional, but no lights. Now if i turn on my bright lights, the little blue indicator light comes on. Any ideas on if there is another fuse hidden, or someone who had this same problem? Thanks.
Mike
Mike
Thats what im saying. Yes ive pulled every fuse (not a noob lol) but im asking if there is one on the backside of the cluster or something. If i dont come up with anything i'll throw the old dx one back in for a bit to test.
Mike
Mike
well, the information was there you just didnt ready the threads,,, if your talking about the 92-95 gauge cluster your gauge dimmer switch wires are on the 12pin gauge clip (or the one on the left side if facing the front of the cluster)and the wires will be the red and the red/black wires. so either do a voltage check on those two wires to find out whether your getting power.
hope that helps.. youcan also get the helms manual in my sig...... pass this on to others, not enough are downloading it..
Thx for the hel cshoe. i'll dick with it tomorrow.
As for human error, nothing was touched its sat the way it is for months, it just stopped working. Thanks for the reply though, it kept my post at the top.
Guest
Posts: n/a
Thats not quite what I meant, when I installed my EX cluster, I noticed the front gauge lights werent working, so I took it back out, and alas I forgot to plug the bulb harness back in after I changed the mileage. Small things like this are frequently overlooked. Just rip the cluster back out and double check all the bulbs.
I see what your saying, but its worked for a long time. I'll pull it apart tomorrow and check voltages. i just didnt know if this was a common problem someone may have heard of. NO biggy, just checking. Thanks ht
timntam
Feb 3, 2006 11:10 AM
1sikcoupe
10
May 7, 2004 03:23 PM
serboy00
Dec 20, 2003 06:49 PM
