95 Accord electrical problem
Old Dec 31, 2003 | 02:09 PM
eldebob's Avatar
Default 95 Accord electrical problem
My friend has a 95 Accord. His battery went dead and he put a new one in. But when he hooked it up he hooked it up backwards, pos on neg and neg on pos. Well he fried the battery, so he got a new one (again) and now his car wont start at all. No power, no anything. What did he break and how can he fix it?
Thankls for your help
eldebob
Old Dec 31, 2003 | 02:22 PM
The_Todd's Avatar
Farts in the shower
Default Re: 95 Accord electrical problem (eldebob)
Just remember red is positive and black is ground/negative.....I would say pop your fuse cover and see whats toast, and if none of those are bad the worst may have happened ecu is ^^ (**** up)
Old Dec 31, 2003 | 05:58 PM
iam7head's Avatar
Default Re: 95 Accord electrical problem (VRDrvr)
Let's hope the fuse is bad, or else it's your car.
check the fuse box under the hood.
that's why you never work on car when you're high..
Old Jan 2, 2004 | 06:48 PM
mwkirchner's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eldebob &raquo;</TD></TR><TR><TD CLASS="quote">My friend has a 95 Accord. His battery went dead and he put a new one in. But when he hooked it up he hooked it up backwards, pos on neg and neg on pos. Well he fried the battery, so he got a new one (again) and now his car wont start at all. No power, no anything. What did he break and how can he fix it?
eldebob</TD></TR></TABLE>
This is exactly why I think that hoods should have locks on them and the owner should not be given a key to it until he passes a test.
That aside ... sounds like he popped the main fuse. Look in the fuse box under the hood and where you see the two kinda thick wires entering the box you should see a fairly thick aluminum fuse there. You will probably see that it is fried in half.
Old Jan 2, 2004 | 07:00 PM
RotaryBzzzz's Avatar
Default Re: 95 Accord electrical problem (mwkirchner)
Yes. Fuses.
Main fusible link is fried. Replace w/ a OEM junk-yard one.
Old Jan 4, 2004 | 09:03 AM
jwogen1's Avatar
Default Re: 95 Accord electrical problem (RotaryBzzzz)
hey man i just read your thread on junkyards, and enjoyed it throughly. i am getting to the stages with my car where i need to start this due to progression of swap and stuff. if you still have all that info handy i would appreciate an email if its not too much trouble(jwogen1@yahoo.com). thanks anyway
Bancas
Feb 5, 2013 03:13 AM
xXxcd5xXx
Jun 24, 2010 05:42 PM
ChinitodeNJ
Jan 9, 2009 08:50 PM
g0at357
May 14, 2008 06:04 PM
boonacka
Dec 16, 2003 03:14 PM
