best compression for Toda B?
Old Dec 31, 2003 | 09:33 AM
gaskleppie's Avatar
Default best compression for Toda B?
Ok, i'm going to do some headwork and also different pistons. But whats the best compression ratio for my B18c6 when i'm gonna install the toda B cams?
I want to make a quench style head like port flow does, and pollish the ports as well.
This is what I got now,
Injen CAI,
HKS 4-1 header
Testpipe
HKS Hipower catback
Old Dec 31, 2003 | 09:59 AM
AssPenny's Avatar
Default Re: best compression for Toda B? (gaskleppie)
I would say higher is better. I plan on swaping some CTR pistons one of these years which gives you a little over 11.5 to 1 I believe.
Old Dec 31, 2003 | 11:06 AM
gaskleppie's Avatar
Default Re: best compression for Toda B? (AssPenny)
Yes, higher is better. But what would be "to much"? and what will be enough?
12:1?
13:1?
14:1? (!)
Old Dec 31, 2003 | 11:19 AM
Dr. EKology's Avatar
High 11's (~11.8 or so) to low 12's. Anything higher than 12.5 would be Toda C territory.
Old Dec 31, 2003 | 11:28 AM
b19coupe's Avatar
Default Re: best compression for Toda B? (EVIL_EKology)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EVIL_EKology &raquo;</TD></TR><TR><TD CLASS="quote">High 11's (~11.8 or so) to low 12's. Anything higher than 12.5 would be Toda C territory.</TD></TR></TABLE>
I am in agreement with EVIL&gt;
Old Dec 31, 2003 | 11:51 AM
PrecisionH23a's Avatar
Default Re: best compression for Toda B? (b19coupe)
And anything higher then a 13.5:1 is usually race gas territory
Old Dec 31, 2003 | 12:26 PM
blykins's Avatar
Banned
Default Re: best compression for Toda B? (GudeH23a)
I have 11.5:1 and use 93. It runs great.
Old Dec 31, 2003 | 01:23 PM
RJL's Avatar
RJL
New User
Default Re: best compression for Toda B? (blykins)
ctr pistons in a b18c5 will yield slightly over 12:1
Old Dec 31, 2003 | 01:35 PM
BlueR's Avatar
Default Re: best compression for Toda B? (RJL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RJL &raquo;</TD></TR><TR><TD CLASS="quote">ctr pistons in a b18c5 will yield slightly over 12:1</TD></TR></TABLE>
most cost effective way to go too
since you are in europe, what is the highest octane/RON gas available?
Old Dec 31, 2003 | 01:39 PM
JjuuN R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GudeH23a &raquo;</TD></TR><TR><TD CLASS="quote">And anything higher then a 13.5:1 is usually race gas territory </TD></TR></TABLE>
i think anything 12:5.1 and above is race gas territory
Old Dec 31, 2003 | 01:46 PM
Default Re: best compression for Toda B? (JUN.R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JUN.R &raquo;</TD></TR><TR><TD CLASS="quote">
i think anything 12:5.1 and above is race gas territory</TD></TR></TABLE>
Personally, I agree with you... But I figured if I said 12.5 to 13:1 it would attract some stupid *** comment from someone who wants to disagree. So i made it 13.5:1 so if anyone did disagree they looked twice as stupid
Old Dec 31, 2003 | 01:48 PM
JjuuN R's Avatar
Old Dec 31, 2003 | 02:20 PM
Big Phat R's Avatar
I'm running Toda B's with 12.5:1 compression (212 whp/144 tq on B18C5 81.5mm bore piston, stock stroke).
It will pre-ignite/ping a lot until you get the motor tuned (ask me how I know)
But once it is tuned - you can use 94 easily and 91 if you're just tooling around town.
Old Dec 31, 2003 | 02:52 PM
blykins's Avatar
Banned
Default Re: best compression for Toda B? (Big Phat R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Big Phat R &raquo;</TD></TR><TR><TD CLASS="quote">
But once it is tuned - you can use 94 easily and 91 if you're just tooling around town.</TD></TR></TABLE>
I would've gone higher compression but I plan on running nitrous w/ the toda's. My friend is running 150shot on his skunk2 stage 2's and he is running 11's untuned shooting fire down the track-lol.
Old Dec 31, 2003 | 03:46 PM
Enrikez's Avatar
better check those clearances with the B's and CTR 's. You will have to advance that intake cam, most likely, a few degrees. just be cautious.
some b16 pistons(jdm or usdm) in that block should also give you around 11.3 + a mugen headgasket and your in safe but good compression for the B's around 11.8/1 .
Its also a good way to stay right under 12./1 CR., 93 octane and timing friendly
Modified by 1meanB18c5civic at 12:59 AM 1/1/2004
Old Dec 31, 2003 | 03:54 PM
JjuuN R's Avatar
yeah that's fine and dandy, but who says it's good to do so? higher compresion, higher octane. period.
i can run 87 all day long with my 12:6.1. won't last long, and i'd be an idiot for doing so, but i can do it
Old Dec 31, 2003 | 04:20 PM
Big Phat R's Avatar
i can run 87 all day long with my 12:6.1. won't last long, and i'd be an idiot for doing so, but i can do it</TD></TR></TABLE>
I would put 100 in my car all the time if I could get it.
Damn Yankee gas stations in the NW only sell 91.
I can get 94 octane in Canada
Old Dec 31, 2003 | 04:31 PM
JjuuN R's Avatar
damn, there has to be something around that sells race fuels. when i had my turbo CRX i always used 116 octane from TRICK. i always got discounts from them since i've been buying fuel from them for like 20+ years now from back when i raced motocross. ask around local shops to see where they get thiers or know of any places.
Old Dec 31, 2003 | 06:44 PM
sgT's Avatar
sgT
Toda C territory? This is BAD logic.
compression depends on availability of high octane fuel and the ability of your tuner.
Has very little to do with cam selection.
Old Dec 31, 2003 | 07:34 PM
JjuuN R's Avatar
Default Re: best compression for Toda B? (sgT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sgT &raquo;</TD></TR><TR><TD CLASS="quote">
Has very little to do with cam selection.</TD></TR></TABLE>
exactly
Old Dec 31, 2003 | 08:09 PM
ITR764's Avatar
compression depends on availability of high octane fuel and the ability of your tuner.</TD></TR></TABLE>
the gas station right down the street from me sells 110. i haven't found out if it's "at the pump" or special request???
Old Dec 31, 2003 | 08:35 PM
esponet's Avatar
12.5:1 or higher is ideal for spec c
so maybe between 11.0:1 -12.0:1 would be ideal for spec b
Old Dec 31, 2003 | 08:42 PM
JjuuN R's Avatar
Default Re: best compression for Toda B? (ITR764)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR764 &raquo;</TD></TR><TR><TD CLASS="quote">
the gas station right down the street from me sells 110. i haven't found out if it's "at the pump" or special request??? </TD></TR></TABLE>
!!!dayamn, awsome
Old Jan 1, 2004 | 05:10 AM
gaskleppie's Avatar
Ok, thanks!
Here in holland we drive 95 or 98 octane fuel. I always run 98. How high can my comp ratio be with this kind of fuel?
Old Jan 1, 2004 | 06:10 AM
NiceITR
Guest
Posts: n/a
How do you know?
