89 Teg ECU in my 90 si civic, good idea or bad? help?
Old Dec 30, 2003 | 09:15 PM
Wes90civic's Avatar
Default 89 Teg ECU in my 90 si civic, good idea or bad? help?
I have a stock d16a6 in my si civic, it has only a intake and exhuast, i was told by a few people i can use a 89 teg ecu to get a little more power, is that true? Also i am going to be doing a port and polish on my head ( thats if my motor isnt fucked, see my other forum) and a cam, plus i am going to be raising my CR a little maybe .5 or so. and Opening up my Throttle body a little bigger. So is it worth switching ecu's, and if so, is $35 a good price for a 89 teg ecu, thanks guys, hope you can help.
Old Dec 30, 2003 | 09:19 PM
Redline130's Avatar
Default Re: 89 Teg ECU in my 90 si civic, good idea or bad? help? (Wes90civic)
For $35 you can't really go wrong. I'd get an adjustable fuel pressure regulator and tune the car on a dyno with a wide band O2 sensor.
Old Dec 30, 2003 | 09:22 PM
crxgator's Avatar
$35 is a great price for that ecu...
as far as gains...well im not too sure if you would gain that much...i know you will get more fuel than the PM6 and your gas mileage would be worse...
Old Dec 30, 2003 | 11:13 PM
rsbad454's Avatar
Default Re: 89 Teg ECU in my 90 si civic, good idea or bad? help? (crxgator)
will work fine......might have some better fuel maps......wont be really any worse mileage.....my 89 teg with stock motor and ECU got about 425miles on one tank.
Old Dec 30, 2003 | 11:59 PM
1CiViC1's Avatar
Default Re: 89 Teg ECU in my 90 si civic, good idea or bad? help? (rsbad454)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rsbad454 &raquo;</TD></TR><TR><TD CLASS="quote">my 89 teg with stock motor and ECU got about 425miles on one tank.</TD></TR></TABLE>
wow, 350/tank for me if im lucky...a lot of stopNgo though...
Old Dec 31, 2003 | 02:47 AM
undefinedcrx's Avatar
lets just say that i actually felt something on the "seat-of-the-pants" dyno, between the 89 Integ (PG7) and the Civic/CRX Si (PM6) computers, with the PG7 being the better choice. im running a d15b2 with siman. & cam, so im sure it should be the same for the d16a6, with the heads being basically identical.
driftam1
Oct 27, 2008 02:43 PM
Wes90civic
Jun 17, 2006 02:39 PM
Red_Si
Apr 29, 2003 12:49 PM
USDM 4G VTEC
May 13, 2002 06:00 AM
civickidd99
Dec 16, 2001 11:30 PM
