My new project to tie me over is in the works!
Yes folks, since I blew all the money I had for the engine/tranny part of the swap on little piddly **** like springs, the mount/linkage kit, Momo steering wheel/hub, and miscellaneous other parts (and household bills), I decided to start out a little cheaper on the motor. If you don't know, I'm sporting the 70 hp 4-spd D15B1 in my STD hatch.
I won a 2000 DX head off of EBay for $85 that only had 1400 miles on it, then I got the intake manifold/throttle body/fuel rail/injectors/ECU and throttle cable coming from an EF Si for $125.
I already have the injector resistor I bought for the B swap, as well as a warm air AEM that I also got for the swap to go on.
I have a cheapy short shift kit, new shift ****, cheapy front/rear strut tower braces, and a rear lower subframe brace. I've got older Eibach springs, but need to get the cash for the adjustable shocks, I've got a '90 Si gauge cluster coming, and some ricey indiglo gauges to put in
and the steering wheel and hub to put in.
I'm pretty psyched! I need to get some gaskets, and head bolts, and some miscellanous piddly **** to get the head on, but basically I'll take a weekend and toss on the head and wire it up.
But this should jump me up from 70 hp to about 100-105, so would be almost a 50% increas in power for about $350, that's a hell of a deal!!
and the steering wheel and hub to put in.I'm pretty psyched! I need to get some gaskets, and head bolts, and some miscellanous piddly **** to get the head on, but basically I'll take a weekend and toss on the head and wire it up.
hmm... good luck on trying to make that go faster... but as for the ricey indiglo gauges... you could've spent your money on something else... hehe
good luck!!
good luck!!
$35 ain't bad, and since I'm getting the Si gauge cluster, it will already be out ..... it all just fell into place!
I don't plan on making this set-up faster, just tie me over until I can convince the wife to let me get the swap!
I already have the B series HCP mount kit and linkage, and the intermediate shaft I'll need and the PR3 ECU, and, and, and ........
I just can't get away with dropping $1500 for the motor/tranny/axles right now (especially since she is still between jobs). Unfortunately with a family and a house, other things come first!
well... hope you get the b-motor... it is the b16a right? keep us updated.. and good luck... i'm still trying to get my rex... payce
Jdmefsir12
Jun 23, 2007 11:07 AM
Jdmefsir12
Jun 22, 2007 07:08 PM
Stavros
10
Jun 1, 2005 04:11 PM
