?????INSTALLATION AND REMOVAL OF CLUTCH CABLE!!!!!!
Old Dec 30, 2003 | 06:43 PM
payneth's Avatar
Default ?????INSTALLATION AND REMOVAL OF CLUTCH CABLE!!!!!!
can someone help me out with this. i am having a hard time removing the clutch cable from the firewall and the tranny itself. i know its probably easy, i just went and baught a brand new one since mine has stretched like a bitch. Any help would be great. thank you.
Old Dec 30, 2003 | 07:13 PM
biggdogg's Avatar
Default Re: ?????INSTALLATION AND REMOVAL OF CLUTCH CABLE!!!!!! (Payneth)
just take the 2 10 mm bolts out of the tranny that hold the cable in line and walla! when you put it back on hook the cable up first to the lower pivot arm and pull the bracket up till the 2 10 mm holes line back up and handstart them back in . tighten down and bam ! back in business.
Old Dec 31, 2003 | 05:53 AM
juanb's Avatar
well all u really have to do is.... remove the cable from the lil arm thats hooked up to the tranny..(u can just slide it right out,if hte cable is loose enough) then just pull it up, when it comes to your firewall, leave it alone as the last thing, go under your dash, look at your clutch pedal, all the way to the top you can see the cable comming thru, its just slipped in the pedal just play with it and it slides right off!! once that is off go to the firewall, and give it a little pull. walla the cable is off!!!
to install new one, first put it threw the firewall slip it on the pedal then put it back on the tranny..
GOOD LUCK
Old Dec 31, 2003 | 07:43 AM
91civicDXdude's Avatar
unscrew the adjuster all the way and pull up on the cable as you remove it from the clutch arm, then slide it out of its holder bracket.
turbo-crx
Oct 7, 2008 02:45 PM
hondateg10
Aug 14, 2007 12:00 PM
Booz
Mar 25, 2007 06:27 PM
EKIM NART
Mar 12, 2006 06:06 PM
Sirex
Sep 26, 2003 07:55 AM
