90-93 jdm integra Xsi cluster?
i was wondering is the 90-93 jdm integra Xsi cluster a direct bolt in or does it need some modification for work ...if so what kind of modification is needed to make it work? if anyone knows or could help it would be appriciated ...
cool ...thanks for the info ...ive been thinking about gettin one for a while now but wasnt sure it would bolt right in ...but now that i know it will im goin to get one ...thanks again ...
Call Thomas at Auto Adventure, they are a huge indoor salvage yard in Portland I believe. I got mine shipped for $100. I dont have their number, but they are on the web.
its the cat sensor light , in the us its the seat belt on , just take the light out , and it is a plug-n-play , and dame 175 i got my cluster for 20 , and i know some other people sellin them for 30-50
I didn't see that anyone mentioned this yet, Yes the cluster will work for the most part but the speedo will be useless. Yes it will move when you drive, but it will not read corectly. There are different speed sensors in the trans. If you want it to read accurately then you need the speedo gear off the trans of the car the cluster came in.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wraith_G2IC »</TD></TR><TR><TD CLASS="quote">I didn't see that anyone mentioned this yet, Yes the cluster will work for the most part but the speedo will be useless. Yes it will move when you drive, but it will not read corectly. There are different speed sensors in the trans. If you want it to read accurately then you need the speedo gear off the trans of the car the cluster came in.</TD></TR></TABLE>
NOT TRUE , IT DOES READ THE SAME , BUT IT WOULD HELP TO LEARN KM
I got that info from a Honda Mech, it seemed to make a lot of sense when you look at a USDM cluster that goes up to 140mph/ ~220kph. The JDM cluster that only goes to ~180kph would be like ~110mph. How does your speedo cable know the difference if you swap clusters? That is why he said the speed sensor in the trans has a different ratio. I have never measured this myself, but like I said, this was told to me by a mech at Honda/Acura. I could be wrong, but it sure sounded like it was accurate.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wraith_G2IC »</TD></TR><TR><TD CLASS="quote">I got that info from a Honda Mech, it seemed to make a lot of sense when you look at a USDM cluster that goes up to 140mph/ ~220kph. The JDM cluster that only goes to ~180kph would be like ~110mph. How does your speedo cable know the difference if you swap clusters? That is why he said the speed sensor in the trans has a different ratio. I have never measured this myself, but like I said, this was told to me by a mech at Honda/Acura. I could be wrong, but it sure sounded like it was accurate.</TD></TR></TABLE>
its the sensor - or what ever they are called - in the cluster , the speedo cable has nothin to do with the cluster
what he is trying to say that it only likes sushi...
LOL
LOL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92integra_gs »</TD></TR><TR><TD CLASS="quote">i seen them go for $100 the most lately</TD></TR></TABLE>
where the hell at??
where the hell at??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IC33 »</TD></TR><TR><TD CLASS="quote">
where the hell at??</TD></TR></TABLE>
http://www.jdmshit.com They have them ..... most of the time...
