Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
h22 swap in a road racer? I searched but couldn't find what i needed
Old Dec 30, 2003 | 04:30 PM
litlekikr's Avatar
Default h22 swap in a road racer? I searched but couldn't find what i needed
if i swap an h22 into a crx, obviously i'd have to compansate for the xtra weight w/ suspension and brake mods etc... but HOW MUCH compensation would i need and would the power output and handling be worth it? Just wondering if this COULD be a better combo then the b18 which i'm running now.
Also, out of curiosity, are there any competitive/ half-way competitive non-vtec cars in H1?
Thanx.
See you all this season
Old Dec 30, 2003 | 08:19 PM
Ninja Kitty
Guest
Posts: n/a
Default Re: h22 swap in a road racer? I searched but couldn't find what i needed (litlekikr)
well IMO a stock h22 is not a better road race engine choice for the CR-x than the b18
The problem is not the weight after all most clases have a minimum and you could easily be well under that. The problem is the size.
It leave you with little room to run a tuned header or a good sized radiator, and the mount kits can put alot of strain on the axles. Plus unlike the b series motors you don't have access to such a large and relatively inexpensive selection of trans and gear ratios.
Durability wise I think the b18 would be better but then if you build your engine then it probably wont matter
If there are non vtec cars doing well they are in the minority. Though that doesn't have to be the case, however most people like the higher base output and shorter gearing of the vtec models.
Personally if my financial situation keeps on doing okay I will be building a second b20 to run h1 with hopefully by mid season.
Old Dec 31, 2003 | 08:23 AM
litlekikr's Avatar
Default Re: h22 swap in a road racer? I searched but couldn't find what i needed (Ninja Kitty)
ok, def. makes sense. Thanx for your help and no smartass remarks.
Thanx again
Old Dec 31, 2003 | 08:29 AM
Willard's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litlekikr &raquo;</TD></TR><TR><TD CLASS="quote">Just wondering if this COULD be a better combo then the b18 which i'm running now.</TD></TR></TABLE>the h22 gearing would be the achilles heal. 3 gears are fun if you have a big block... but not a 4 cyl.
Old Dec 31, 2003 | 09:24 AM
Tyson's Avatar
could be wrong, but i think fastom's accord has n h22 in it. or it might just be a b18C5. i think hasport put a h22 in an accord or integra and they had a lot of suspension problems because it was too front heavy.
youre not going to read about it much since it doesnt happen much.
Old Dec 31, 2003 | 10:16 AM
goforbroke's Avatar
MEAT PATTY
Default Re: h22 swap in a road racer? I searched but couldn't find what i needed (Tyson)
I'm swapping a h22 or f20b into my cx over the winter hopefully after its all built. And its going to be my autox car and I'm thinking about road racing it a little also, but that all depends. But I wouldn't put a h22 into a crx their isn't enough room for radiators, and ect...... I know its going to be a little front heavy but I think I have that pretty much taken care of, within the rule book rules.
Old Dec 31, 2003 | 04:22 PM
Honda318dx's Avatar
Default Re: h22 swap in a road racer? I searched but couldn't find what i needed (Willard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Willard &raquo;</TD></TR><TR><TD CLASS="quote">the h22 gearing would be the achilles heal. 3 gears are fun if you have a big block... but not a 4 cyl.</TD></TR></TABLE>
Common misconception my friend.. Per RPM, the H22a1 m2f4 tranny is geared lower than a 4.9 ITR tranny.. My STOCK prelude tranny tops out at 139mph, where I think a same sized tired 4.9 ITR will do 145...
I havn't driven a car that is geared shorter per gear to its redline, then the prelude vtec ones..
Old Dec 31, 2003 | 04:31 PM
Willard's Avatar
Default Re: h22 swap in a road racer? I searched but couldn't find what i needed (Honda318dx)
if you use an Accord tranny.
3rd = 110mph?
Old Jan 1, 2004 | 06:37 AM
Honda318dx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Willard &raquo;</TD></TR><TR><TD CLASS="quote">if you use an Accord tranny.
3rd = 110mph? </TD></TR></TABLE>
Very true.. don't give out any secrets of my h1 tranny now...
Old Jan 1, 2004 | 08:27 AM
chad's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda318dx &raquo;</TD></TR><TR><TD CLASS="quote">
I havn't driven a car that is geared shorter per gear to its redline, then the prelude vtec ones.. </TD></TR></TABLE>
i agree with corey on this.....99.999% of the people out there that say this is a "BAD SWAP" have no clue!!!!!!!!!!!1 period!!!!! this setup in a hatch or crx is gonna be fast!!!!
even a stock h22 in a crx is a mid 12 second car with no mods....no b series is gonna get close to that STOCK FOR STOCK!!
this means every straight you are probably gonna pull 1-2 seconds away....and you can easily compensate for the 50-75 extra lbs....
and you can't run a tuned header?? what are you smoking dude!!! that was the dumbest statement of 04 so far....
i would try this in a hatch but funding does not allow it!!!
Old Jan 1, 2004 | 08:31 AM
.RJ's Avatar
.RJ
Default Re: h22 swap in a road racer? I searched but couldn't find what i needed (chad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad &raquo;</TD></TR><TR><TD CLASS="quote">i would try this in a hatch but funding does not allow it!!!</TD></TR></TABLE>
Are h-motors more expensive when they blow up?
RJ - ducking and running
Old Jan 1, 2004 | 07:57 PM
Ninja Kitty
Guest
Posts: n/a
Default Re: h22 swap in a road racer? I searched but couldn't find what i needed (.RJ)
this is a what a tuned header might look like and even this will not fit in the CRX chasis, I don't remeber saying it's impossible however it's going to be difficult when barely the stock EM fits.
Old Jan 1, 2004 | 09:17 PM
goforbroke's Avatar
MEAT PATTY
Chad, this isn't a drag race man, but I do understand what you are trying to imply about the straight away speed. Yeah but what happens when you have to brake down that long front straight away, with all that weight pushing up front. But I really can't say anything because I"m swapping one in my car also. I just think it would be a little more difficult to get it handle "decently" in a crx opposed to a newer generation hatch like you have. I just picture it understeering way too much are turns unless he is going to have hoosiers
Old Jan 2, 2004 | 02:24 PM
Ninja Kitty
Guest
Posts: n/a
Default Re: h22 swap in a road racer? I searched but couldn't find what i needed (goforbroke)
actually an h22 in race trim might be only 100 or less pounds heavier in the front than a stock crx considering lightweight hood and bolt ons flywheel rims ect, and you can easily position matching weight in the rear to make class minimums.
Old Jan 2, 2004 | 03:45 PM
Honda318dx's Avatar
It will out drag everything, thats for sure.. H22a is a STONG motor.. Can't wait to unleash mine on a diet..
Old Jan 2, 2004 | 05:01 PM
Ninja Kitty
Guest
Posts: n/a
yeah yeah he said unleash,
super gundam beef tree attack yO!
I always liked the Prelude the best it's good to see some actually RR. Too bad all the stunnas on the WCHC will have h22 defeating k20 mottas next year it seems. Of coure Type S and Euro R parts R factory Honda muhuhahahaha !
94prelude1488
31
Jul 18, 2012 05:35 AM
ekkkk20
34
Mar 26, 2008 10:13 AM
iNDiO
Jan 27, 2008 03:16 PM
djnikko
Sep 5, 2004 11:12 PM
iwhichisme
Sep 28, 2002 02:06 PM
