B16/OBD1/EG swap question
Old Dec 30, 2003 | 03:49 PM
endlesswinterco's Avatar
Default B16/OBD1/EG swap question
I just swaped a b16a2 into my eg. im running the del sol dohc vtec ecu. My stock O2 sensor is a single wire out of a cx. i was told i need to swap over to a four wire. is taht true, and if so, how do i do it. thanks. ben
Old Dec 30, 2003 | 03:57 PM
nsxmatt's Avatar
Default Re: B16/OBD1/EG swap question (RidinlowHatch)
Get a 4-wire O2 sensor and run all 4 wires direct to the wires going into the ECU.
Old Dec 30, 2003 | 04:10 PM
Default Re: B16/OBD1/EG swap question (nsxmatt)
do you know the pin outs for the o2?
Old Dec 31, 2003 | 03:27 AM
up, still need help
Old Dec 31, 2003 | 03:51 AM
LegoZ81's Avatar
first off you will need ideally have helms manuals for a DelSol and you car. second here are the pinouts for the P30:
http://tech2.hybridgarage.com/..._obd1
A6 ORN/BLK PO2SHTC O2 sensor (heating element)
D14 WHT PHO2S O2 sensor
you will need helms to find out what needs to be connected to those pins I am forget right now I think it is the ground wire for the heater @ a6
and the green signal wire for D14 not sure though CHECK YOUR HELMS!
stollen from Hybrid Garage
The information provided here is intended to inform the reader of what is possible. However, there may be errors or mistakes. Verify any info here with other credible sources before proceeding. I will not accept responsibility for any harm or loss that results from ideas or information in this post.
Old Dec 31, 2003 | 12:54 PM
Default Re: B16/OBD1/EG swap question (LegoZ81)
thanks, i got the info from another board member.
tibss
Jan 21, 2008 09:52 AM
P12 EG6
Oct 19, 2007 11:14 PM
dropd4door
10
Dec 27, 2004 06:07 PM
Casey
Feb 8, 2004 05:46 PM
endlesswinterco
Dec 31, 2003 12:54 PM
