please help me!sorry not much in the topic but come in please
can you check the link and then tell me what the problem is or is it supposed to do that https://honda-tech.com/zerothread?id=719227 thanks much later
it's time to replace your PCV valve. If you still have the oil problem after the PCV valve is replaced, your piston rings are probably worn out.
Toostinky
Dec 15, 2003 01:08 PM
