need help finding location of fuel pump wire(installing kill switch) 5th gen
Old Dec 30, 2003 | 02:07 PM
gaydm.accord's Avatar
Default need help finding location of fuel pump wire(installing kill switch) 5th gen
ok i know that the 5th gen accords fuel pump are not as easily accessed under the rear seats, you'd have to drop the gas tank. does anyone know an easier way or which/where the fuel pump wire can easily be accessed?
Old Jan 3, 2004 | 01:56 AM
E-brake or Handbrake's Avatar
Default Re: need help finding location of fuel pump wire(installing kill switch) 5th gen (gaydm.accord)
bump for a fellow ricer
Old Jan 3, 2004 | 02:03 AM
yes rice rice baby
Old Jan 3, 2004 | 05:52 AM
m0t0rhead's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gaydm.accord &raquo;</TD></TR><TR><TD CLASS="quote">ok i know that the 5th gen accords fuel pump are not as easily accessed under the rear seats, you'd have to drop the gas tank. does anyone know an easier way or which/where the fuel pump wire can easily be accessed?</TD></TR></TABLE>
The fuel pump can be access from the trunk of your accord. The connecter and access point in located underneath your trunk board. Pull it out and you'll see it.
Old Jan 3, 2004 | 07:53 AM
brads94accord's Avatar
Default Re: need help finding location of fuel pump wire(installing kill switch) 5th gen (Escobar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Escobar &raquo;</TD></TR><TR><TD CLASS="quote">
The fuel pump can be access from the trunk of your accord. The connecter and access point in located underneath your trunk board. Pull it out and you'll see it. </TD></TR></TABLE> actually to access the fuel pump in a 5th gen you have to drop the tank, that little thing in the trunk is the sending unit i believe. but i think those wires there are also to the fuel pump.
Old Jan 3, 2004 | 11:19 AM
m0t0rhead's Avatar
Default Re: need help finding location of fuel pump wire(installing kill switch) 5th gen (brads94accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brads94accord &raquo;</TD></TR><TR><TD CLASS="quote"> actually to access the fuel pump in a 5th gen you have to drop the tank, that little thing in the trunk is the sending unit i believe. but i think those wires there are also to the fuel pump.</TD></TR></TABLE>
You're correct... but.. He's not wanting to replace his fuel pump. He wants to wire a kill switch and the connector to the pump is in the trunk.
Old Jan 3, 2004 | 02:15 PM
thanks escobar, and is thethe fuel pump wire the same as on other hondas yellow with green stripe?
Old Jan 3, 2004 | 07:20 PM
mwkirchner's Avatar
<FONT SIZE="4">The wire you want is black with a yellow tracer ...</FONT>
Old Jan 3, 2004 | 07:30 PM
thanks
Old May 1, 2004 | 02:30 PM
Mod_Accord's Avatar
Default 96 Accord
I am looking for the color code for the wiring of a Fuel Pump in a 96 Accord. I would like to install a fuel pump kill switch, but don't know the best way to go about that, plus where would be a good place to access this wire, but secure. Thanks.
Old May 1, 2004 | 03:26 PM
the trunk, lift up the spare tire cover and its there
read before posting
you might also want to read the TOS
Old May 2, 2004 | 02:12 PM
Mod_Accord's Avatar
Default Re: (gaydm.accord)
To gaydm.accord. Thank you for the reply. I was unware that the 5th gen refers to the 96 Accord. I am new to these kind of forums and lingo and so far have enjoyed my experience thus far. I have read the T.O.S. Have a nice day.
Old May 2, 2004 | 03:52 PM
no problem.... just trying to help a fellow ht-er out, its kinda harsh in here.
joeyt
Honda Civic (2001 - 2005)
10
Dec 24, 2008 10:40 AM
1LEWDh22
Jun 20, 2007 09:58 PM
accordredliner
Feb 26, 2006 02:41 AM
dvp95
May 29, 2003 09:40 PM
