steerinig rack removal
Old Dec 30, 2003 | 01:28 PM
DanR's Avatar
Default steering rack removal
I posted a few weeks ago about replacing the front cross member because of damage from daughter meeting a curb in the snow. Well I am tearing it down and stumped as to disconnect the steering wheel shaft from the rack. If any body has any hints they would be most appreciated. It's a 92 with power steering. Seems so far as the only damage is the cross member, maybe we got lucky.
Thanks again,
Modified by DanR at 11:19 PM 12/30/2003
Old Dec 30, 2003 | 01:46 PM
.bagged's Avatar
Default Re: steerinig rack removal (DanR)
Start with disconnecting you PS fluid lines and drain them
Old Dec 30, 2003 | 02:14 PM
DanR's Avatar
Default Re: steerinig rack removal (bagged93accord)
That is done already, the only thing holding the rack on is the steering colum at the rack.
Old Jan 2, 2004 | 09:36 AM
DanR's Avatar
Default Re: steering rack removal (DanR)
Found the connection to the steering rack, the universal joint is located under the brake pedal in the cabin. One has remove the bolt from the clamp to allow the rack shaft to drop down and out.
DanR
yohimbine
Sep 12, 2013 08:49 PM
B18B EK
Apr 7, 2010 06:38 PM
dr_latino999
Jun 17, 2008 09:59 AM
Pvt Fields
Mar 31, 2008 01:59 PM
RanCRX
10
Oct 9, 2007 05:44 PM
