swapped tranny locked up...fixable?
So I started the GSR motor yesterday to see if the swap that took all weekend was going to be worth it. Well when I released the clutch (in neutral) the car stalled. Hmmm...then I tried shifting it into gear - NOPE! I got it into 4th gear eventually, and now it won't come out of it.
Is there anyway to fix this problem?
well after you bleed the clutch, and it still hasnt fixed anything. You'll eventually have to pull the tranny.
I highly doubt your tranny just "gave out." Most likely your clutch disc binded to your pressure plate and isn't releasing.
Like did pedal pressure increase and become almost impossible to push down? Or did you loose hydraulic pressure and the pedal fall to the floor?
Well I'm used to an ACT HDSS clutch on my LS...this clutch I believe is stock. The pedal pressure is very soft. The pedal does go to floor but will return like normal
litterbox
Sep 28, 2005 09:41 AM
