Mugen thermostat gone bad ??
Old Dec 30, 2003 | 09:37 AM
iperez's Avatar
Default Mugen thermostat gone bad ??
I have a Mugen thermostat in my ITR that has been installed for about 20K miles. Yesterday, my car's temperature was rising above what is normal so I took it to the dealer. They tell me that the problem is that the t-stat has gone bad. How can I tell if, in fact, my problem is the thermostat ??
It is worth mentioning that last week I ran the car with too little coolant and the temp did rise above normal but not as high as the max on the indicator gauge. The coolant problem was resolved that same day. Could this have messed up the thermostat ??
Old Dec 30, 2003 | 09:43 AM
96 Ls lnTeG's Avatar
Default Re: Mugen thermostat gone bad ?? (iperez)
were you using a stock radiator cap with T-stat?? I read somewhere you are suppose to use both in conjuction or Tstat will get ruinied faster
Old Dec 30, 2003 | 09:44 AM
Reid's Avatar
Global Moderator
Put your thermostat and a thermometer in a pot of boiling water and you will find out the temp at which the thermostat opens.
Old Dec 30, 2003 | 10:01 AM
iperez's Avatar
I was using the Mugen radiator cap but the thermoswitch is OEM, not Mugen.
Old Dec 30, 2003 | 06:11 PM
an2ny888's Avatar
Default Re: (iperez)
my tstat went bad too, but mine resulted in the car not running hot enough most of the time.
Old Dec 30, 2003 | 07:08 PM
AlphaKennyWun's Avatar
Default Re: (an2ny888)
Air may have gone in when coolant was low. Bleed the coolant using that little bleeder plug on block. Try soemthing free first before you let the dealer touch it or spend money.
Old Dec 30, 2003 | 07:44 PM
RockstarJR's Avatar
that sucks...
Old Dec 30, 2003 | 08:19 PM
ArmyGreenITR's Avatar
Default Re: Mugen thermostat gone bad ?? (ItrChris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ItrChris &raquo;</TD></TR><TR><TD CLASS="quote">that sucks...</TD></TR></TABLE>
post ***** ....
Sounds like its is possibly the thermostat,sucks that a Mugen one went out so quick.
Old Dec 31, 2003 | 04:06 AM
iperez's Avatar
Well, I did bleed the sistem last week when the car ran low on coolant. Actually, bleed, flush, and refill with new fluid. I would have thought the car would run cold if the t-stat died ?? Anyway, the guy at the dealer is taking care of it under warranty (apparently, he could not tell the difference between the Mugen t-stat and the OEM part) so I'm still not dishing out cash for this ..
Old Dec 31, 2003 | 06:05 AM
T I F O S I's Avatar
if you dont have the mugen switch, then how is the thermostat supposed to open earlier? if i were you i would have bought the mugen switch with it as this is how it is supposed to be purchased and installed.. i have both in my b18c swapped ek and have never had any problems... car doesnt get warm very well though
Old Dec 31, 2003 | 06:24 AM
Mugen Mike's Avatar
Default Re: Mugen thermostat gone bad ?? (goldeknug)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goldeknug &raquo;</TD></TR><TR><TD CLASS="quote">if you dont have the mugen switch, then how is the thermostat supposed to open earlier? if i were you i would have bought the mugen switch with it as this is how it is supposed to be purchased and installed</TD></TR></TABLE>
You don't need to use both the fan switch and thermostat together -- they work independently of each other, and some say the car will run too cold using both in a street car. The only way the thermostat will open earlier is if the fan switch is NOT used.
Old Dec 31, 2003 | 06:30 AM
Default Re: Mugen thermostat gone bad ?? (Mugen Mike)
haha leave it to mike to totally prove me wrong.. well he needs the right answers regaurdless.. good job mike
Old Dec 31, 2003 | 06:31 AM
ZygSpeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugen Mike &raquo;</TD></TR><TR><TD CLASS="quote">You don't need to use both the fan switch and thermostat together -- they work independently of each other!</TD></TR></TABLE>
Exactly what I was going to say!
Old Dec 31, 2003 | 09:27 AM
iperez's Avatar
Well, this is Puerto Rico, so my main concern would be to keep the car from heating up
Old Dec 31, 2003 | 10:47 AM
Default Re: Mugen thermostat gone bad ?? (zygspeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zygspeed &raquo;</TD></TR><TR><TD CLASS="quote">
Exactly what I was going to say!</TD></TR></TABLE>
***** it up why dont you!!
whoring it up myself with this post
Old Dec 31, 2003 | 10:51 AM
Opie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goldeknug &raquo;</TD></TR><TR><TD CLASS="quote">***** it up why dont you!! </TD></TR></TABLE>
Plans on whoring everything up tonite
Old Dec 31, 2003 | 10:55 AM
Tweakmeister's Avatar
Default Re: Mugen thermostat gone bad ?? (opie112)
they usually break in the open position...ie your car will run too cold.
Old Dec 31, 2003 | 11:04 AM
Mike M's Avatar
Founding Member
Default Re: Mugen thermostat gone bad ?? (Reid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reid &raquo;</TD></TR><TR><TD CLASS="quote">Put your thermostat and a thermometer in a pot of boiling water and you will find out the temp at which the thermostat opens.</TD></TR></TABLE>
Old Dec 31, 2003 | 02:24 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by opie112 &raquo;</TD></TR><TR><TD CLASS="quote">
Plans on whoring everything up tonite </TD></TR></TABLE>
plans on giving you an E-high five, in the 2004
Old Dec 31, 2003 | 04:01 PM
JjuuN R's Avatar
Default Re: (S03Burner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S03Burner &raquo;</TD></TR><TR><TD CLASS="quote">Air may have gone in when coolant was low. Bleed the coolant using that little bleeder plug on block. Try soemthing free first before you let the dealer touch it or spend money.</TD></TR></TABLE>
Old Jan 2, 2004 | 02:42 AM
ek4ek9's Avatar
since you guys are on this topic..may i know if there would be a problem using
say a spoon thermostat and a mugen fan switch + a spoon rad cap combination?
i was told that the spoon and mugen fan switch are the same..anyone to confirm this...and i was thinking of going to that setup coz the mugen fan switch is cheaper and the spoon thermostat opens earlier...so what do you guys think, before i make the purchase..thx
importknight
Nov 6, 2010 11:22 AM
fridexter
Nov 21, 2004 12:44 PM
tc
Jul 5, 2003 02:42 PM
Islander9407
Jul 27, 2001 12:34 PM
