Noise coming from the engine???
Old Dec 30, 2003 | 08:44 AM
rickytz7111's Avatar
Default Noise coming from the engine???
Hello to all of you. I have a questin about my 1994 accord lx. I bought it about 2 weeks ago. When the car is in idle and I give it a little gas i'm not certaing at what rpm I have it at I can here something like it's knocking or ticking or clicking. It's really hard to describe. This after the car is warmed up. I think that I here some chattering when I first start it up on a cold morning. The car has 153k on it. The guy that I just bought it from had all the routine maint. done on it. It just had a valve job done in may and the car had 149k on it then. Could they have done the valve adj. wrong? I would appreciate any info that you guys can give me. Thanks
Old Dec 30, 2003 | 09:31 AM
Elvis1977's Avatar
Default Re: Noise coming from the engine??? (rickytz7111)
noise in the mornings is Normal for Honda engines. Some noise from a warmed up engine with 153k is also normal, but depends on how it sounds.
Old Dec 30, 2003 | 12:49 PM
The_Todd's Avatar
Farts in the shower
Default Re: Noise coming from the engine??? (Elvis1977)
My car has had that noise from 80K till now 172K, it hasn't gotten louder I think its just how honda's are......but if it were to get worse I would get the valves checked. IF its really loud and noticable get it checked, mine is barely noticable over the intake sucking in air.
Old Dec 31, 2003 | 03:57 AM
Thanks for the info guys. It sounds like something is ticking or knocking when I first start it up then it goes away after a couple of minutes. The car has plenty of power and it doesn't make any noise when i'm driving it.
Old Dec 31, 2003 | 05:11 AM
Elvis1977's Avatar
NORMAL HONDA ENGINE NOISE. IF your car was a TOYOTA then it will run like a sewing machine even with 153k. Toyota's are simply quieter than Honda's.
Old Jan 1, 2004 | 11:00 AM
tonezilla's Avatar
i dont know if this is related butt recently my car made a loud ticking or squeaking sound when i turned it on . thought it was normal but i found out that my belts were going bad . that could be one of the reasons .
Stevo F
Jul 14, 2014 07:25 PM
v8killaz
May 13, 2009 09:41 PM
pimpinainteasy
Aug 4, 2003 02:51 PM
MKX-R
Jul 9, 2003 12:54 PM
