ECU
Old Dec 29, 2003 | 09:19 PM
Civmochris's Avatar
Default ECU
Is there anyway that i can run the pm6 with out doing the mpfi swap on my std. i tried putting it on but it would not let me go above 3,500 but ran great till then. when i hit 3,500 it sounded like i was hitting rev limiter. any info is greatly appriciated
Old Dec 29, 2003 | 09:39 PM
Civmochris's Avatar
Default Re: ECU (Civmochris)
if any one knows anything please let me know
Old Dec 29, 2003 | 09:43 PM
crxgator's Avatar
probably not, its probably looking for the 2 injectors you are missing...get the correct ecu...
Old Dec 29, 2003 | 09:55 PM
Civmochris's Avatar
i have the right ecu but the ecu pm6 has been chipped so i would like to run that if i could until i do my mpfi swap
Old Dec 29, 2003 | 10:01 PM
crxgator's Avatar
obviously if you are using that ecu with your motor at this time, it isnt the right ecu...use the correct pm5 untill you do the mpfi...
91civicEX's Avatar
whoa i missread that completely. you can run the pm6 on ur car. if it ran it was only on two injectors.
Old Dec 30, 2003 | 09:41 AM
Civmochris's Avatar
i am runnig the stock pm5 ecu on the car right know and i was wondering if there was anyway to rewire something so that the pm6 would work
kyle48_2007
20
Apr 29, 2013 04:31 PM
scabbs
Oct 19, 2006 05:49 PM
DieMaster
Jul 13, 2004 12:00 PM
turbotime
Jul 14, 2003 09:54 AM
dellman177
Apr 25, 2003 04:39 AM
