Should I buy skunk two stage two cams for my 95 gsr
Old Dec 29, 2003 | 05:54 PM
deceptiongsr's Avatar
Default Should I buy skunk two stage two cams for my 95 gsr
I want some more power but still need the car to be daily drivable. Shold I throw in some cams and if yes... how much should i pay for them. also... if I get cams, do i need springs and retainers and valves...
Old Dec 30, 2003 | 03:07 AM
b19coupe's Avatar
Default Re: Should I buy skunk two stage two cams for my 95 gsr (deceptiongsr)
For a stock compression GSR you could run Toda 'A's , Skunk 2 stage 1's, or equivalent. You should at least upgrade your valve springs to ITR valve springs. Buy a set of ITR intake valve springs and swap your GSR intake springs to the exhaust side. Stock retainers will be fine for this setup. And you can run the stock ECU with those cams.
Old Dec 31, 2003 | 02:41 PM
b18cpower's Avatar
If you buy stage 2 you need to replace your springs/retainers. Also to up your compression to at least 11.5:1. You should just get ctr cams and an itr valvetrain. Those are cheaper and can give some good power with other basic bolt ons and tuning.
Old Dec 31, 2003 | 09:59 PM
SiB16A's Avatar
Default Re: (b18cpower)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18cpower &raquo;</TD></TR><TR><TD CLASS="quote">If you buy stage 2 you need to replace your springs/retainers. Also to up your compression to at least 11.5:1. You should just get ctr cams and an itr valvetrain. Those are cheaper and can give some good power with other basic bolt ons and tuning. </TD></TR></TABLE>
If you get ctr cams and an itr valuetrain for a b16a head can you use your stock bottom end?
Old Jan 1, 2004 | 12:20 AM
DVS_EF's Avatar
Default Re: (SiB16a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiB16a &raquo;</TD></TR><TR><TD CLASS="quote">
If you get ctr cams and an itr valuetrain for a b16a head can you use your stock bottom end?</TD></TR></TABLE>
yes you can...
Old Jan 4, 2004 | 08:51 AM
SiB16A's Avatar
Default Re: (12'sALLDAY)
thanks
starcraftbw
20
Aug 14, 2007 05:45 PM
longfellahh
Mar 8, 2006 05:36 PM
grenthang
Mar 13, 2005 11:57 AM
Im-Gay
Aug 16, 2004 06:08 PM
hulkhb
20
Jul 17, 2003 08:20 AM
