Which is better? Jun or Toda cams
Old Sep 24, 2001 | 11:57 PM
tomorrow's Avatar
Default Which is better? Jun or Toda cams
Please share you're thoughts on these cams ?
Old Sep 25, 2001 | 12:01 AM
B18C-EJ1
Guest
Posts: n/a
Default Re: Which is better? Jun or Toda cams (tomorrow)
Which is better Ford or Chevy?
It's all a matter of opinion.
Old Sep 25, 2001 | 12:03 AM
BoostinDC2's Avatar
Default Re: Which is better? Jun or Toda cams (B18C-EJ1)
http://www.importreview.com
check them out they have those 2 cams compared to each other
Old Sep 25, 2001 | 04:26 AM
CRX_VTEC's Avatar
Default Re: Which is better? Jun or Toda cams (BoostinDC2)
I really cant go wrong with either one. I've seen dyno's for both and both make good power. I hear Toda need more fine tuning to maximize power, but can push just as many HP as Jun.
Old Sep 25, 2001 | 07:50 AM
AllMotorMadness's Avatar
Jun 3's
Old Sep 25, 2001 | 08:22 AM
Black R's Avatar
25 Year Member
what do you want to use them for?
how fast do you want to go?
midrange or peak whp?
Old Sep 25, 2001 | 09:35 AM
Maybe this would help you decide which cam to go with check it out:
http://www.importreview.com/reviews/...n3VStyper.html
Old Sep 25, 2001 | 11:18 AM
VTC_CiViC's Avatar
Default Re: Which is better? Jun or Toda cams (AllMotor_2.0L B18C5)
Question, were those B18C5 or B16B cams on that trio test? I'm intrested in a set of cams for my 99 GS-R, but not sure to go with B16B's or B18C5's.
Old Sep 25, 2001 | 12:47 PM
BoostinDC2's Avatar
Default Re: Which is better? Jun or Toda cams (CRX_VTEC)
JUN 3's
Old Sep 25, 2001 | 06:03 PM
alexboy's Avatar
are jun 3 more or less streetable on a 99 gsr with stock compression or should i stick with gettin jun 2's with stock compression
Old Sep 25, 2001 | 07:15 PM
1.8EG-T's Avatar
Why don't you consider the crower cams, some of them make good power, just forgot which number does, also they are cheaper, which means you could get the cams and gears for the price of some jun stage 3 or toda spec b's. Just a thought.
Old Sep 25, 2001 | 09:06 PM
Blade's Avatar
New User
The reviews done on that site should be taken with a grain of salt and its one persons experience who seemed to be anti-TODA from the start because as he put it "I only help compaines who help me, and TODA didn't give me any free cams to test".
Go to http://www.dynocenter.com various people (not just one guy) have their dyno runs with TODA cams there. The difference between JUN and TODA seems to be in the midrange where TODA makes more power and with a smooth vtec crossover. The top end is about the same between the two cams. TODA is better suited for road racing.
Old Sep 25, 2001 | 11:22 PM
B18C-EJ1
Guest
Posts: n/a
Default Re: Which is better? Jun or Toda cams (Blade)
Where, there's nothing but a front page with an integra there. When will the real site be available? Geoshitty's webpages makes me think twice.......
Old Sep 26, 2001 | 08:06 AM
WAFFLES's Avatar
Any one have some dyno charts on the Spoon cams? Also, not sure if this was covered, but were the Type R cams CTR or ITR intake?
Old Sep 26, 2001 | 09:41 AM
d0nkeyxPunch's Avatar
Banned
Get the Toda Vtec Killer cams!
Old Sep 26, 2001 | 11:10 AM
976's Avatar
976
New User
Default Re: Which is better? Jun or Toda cams (FastxCivic)
They did the dyno for each, answer solved.
Old Sep 26, 2001 | 12:52 PM
alexboy's Avatar
Default Re: Which is better? Jun or Toda cams (alexboy)
Old Sep 26, 2001 | 01:20 PM
AJ PwR's Avatar
Jun and Toda are very good cams FMO, I think both cams have significant power gains. Depends on your setup to figure which cams work better.
Old Sep 27, 2001 | 08:54 AM
BoM's Avatar
BoM
Default Re: Which is better? Jun or Toda cams (AJ PwR)
Has anyone heard of JUN cams wrecking some peoples engines? like it wasn't installed by a professional shop that didn't know JUN's specs...i remember a post about this like last year...
Old Sep 27, 2001 | 11:59 AM
alexboy's Avatar
Default Re: Which is better? Jun or Toda cams (bommiE)
what would the vtec x over in the jun3 be what would it be for the jun2 as well
LilCivic04
24
Jun 23, 2008 06:15 AM
hybrid_vtec
14
Sep 8, 2004 01:23 PM
TEGPOWER44
Jul 7, 2002 12:03 PM
NewbieFirstTimer
Jul 2, 2002 07:46 PM
