Apexi N1 Coilovers
Old Sep 24, 2001 | 10:15 PM
Cyrio's Avatar
Default Apexi N1 Coilovers
Does anyone have this suspension, and how do you like it?
Type Goch's Avatar
New User
Default Re: Apexi N1 Coilovers (Cyrio)
talk ta EP...he had it for a while..seems to enjoy em but i think hes gonna like his new ones!
Old Sep 25, 2001 | 04:48 AM
Dropspeed's Avatar
Default Re: Apexi N1 Coilovers (Type Goch)
I like them, They are a good all-around suspension Mine serve as street/track duty. I would like them a little stiffer for the track but they are fine. No problems.
Mattj
Old Sep 25, 2001 | 05:05 AM
Petah's Avatar
Default Re: Apexi N1 Coilovers (Dropspeed)
I like mine. Perfect for street/track use. However, i would like to have better spring rates. I think they came with 11k front and 5k rear. But that can be solved by buying a set of eibach flat top springs that are 14k to be used in the front and moving the 11k to the rear.
[Modified by eg-six, 6:05 AM 9/25/2001]
Old Sep 25, 2001 | 02:06 PM
Cyrio's Avatar
Dropspeed: Do you use a camber kit?
Old Sep 25, 2001 | 03:07 PM
bhcvc's Avatar
I like mine a lot. The only thing I would change is the damping adjustment, which isn't very intuitive (there's only 13 adjustments, but you can turn the key about 43-44 clicks before it stops). It'd be a lot easier if they just allowed you turn them exactly 13 clicks. Aside from that, they're a good track and street coilover. The spring rates are 9kg-F/5kg-R. Tho I really like my N1's, I want to try out JIC coilovers. Hmmm...should I sell...hmmm...
Old Sep 25, 2001 | 03:28 PM
Cyrio's Avatar
Default Re: Apexi N1 Coilovers (bhcvc)
bhcvc: What kinda car do you have? Lemme know if you think about selling.
Old Sep 25, 2001 | 04:18 PM
bhcvc's Avatar
I have a 98 civic. What do you have?..ITR?
Old Sep 25, 2001 | 04:37 PM
Mario's Avatar
At the front its 11kg/mm for Integras and 9kg/mm on the Civic N1s. 5kg/mm at the rear for both cars.
Yeah, Eibach ERS springs will probably fit.
If you can manage it, try to get the Apexi N1 Type PRO rather than the Type R. Not only do you get stiffer springs, the diameter of the pistons is bigger=better damping adjustment.
Old Sep 25, 2001 | 05:31 PM
Petah's Avatar
Default Re: Apexi N1 Coilovers (Supersonic DC2)
From what i heard, there are some deffects to these shocks (spec 99)........i havn't had any problems with mine yet. Has anyone had problems or have heard of this as well?
Old Sep 25, 2001 | 07:33 PM
Cyrio's Avatar
Default Re: Apexi N1 Coilovers (eg-six)
Damnit, I just want a some what inexpensive way to lower this bitch, without messing up the handling.
Old Sep 25, 2001 | 07:36 PM
Type Goch's Avatar
New User
lowdowns?
Old Sep 25, 2001 | 07:43 PM
Cyrio's Avatar
I might as well just fork out the cash and get teins...
Anyone got a set laying around?
[Modified by Cyrio, 9:01 PM 9/25/2001]
Old Sep 25, 2001 | 08:56 PM
ITR.00-1282
Guest
Posts: n/a
when i had them on my car the handling was incredible. obvious improvement over stock. i'm not an auto x'er or anything and they (the N1s) were badass on the street.
95sihb
Suspension & Brakes
28
May 20, 2005 10:19 AM
2000 Integra R #760
Sep 19, 2002 06:00 PM
Rhetoric
Feb 20, 2002 04:12 PM
