Parts Available For The ZC?
lot of things if you look, its not easy to find, there are some reputible places doing Regrinds. Exospeed (I have a stage 2) and a couple otheres Ef-1 and ZCboyz or something like that. Its a motor that likes to breath and runs very well with a 100lb weight advantage over a B16 for those of you who are weight concience. Its about $1,000 lest to swap one than a B16 swap will run after custom mounts etc. For that difference you will be pushing as much as you will on a stock B16 and have 100lbs less weight to haul around than a B16 will. For those of you who count ounces thats a hell of a lot of weight to shed to get weight parity from a B16 pushing the same power as a modded DOHC ZC.
Yeah the B16 has more potential but most of use don't go beyond bolt ons anyway. So it matters.
