Gonna give K a miss....I think....
Well, I've pulled the motor and this is how it is at the moment
http://www.pbase.com/image/23644677
I've been tossing up a motor to get me into the 11's on street tyres. I was looking at about 250whp to get my 1700lb (with me) there. Costs for the 250whp K conversion were looking @ around $10000US.
I wanna do something different (Believe me, in Australia, all motor Hondas are different) so it looks like I'm gonna build a motor like Bisi's except a little milder...and injected.
Thoughts, comments????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drag_Racer_DRU »</TD></TR><TR><TD CLASS="quote">yikes how are you going to hook up with 250whp?</TD></TR></TABLE>
225/60 x 15 BFG Drag Radials + 1700lb = "reasonable" launch
1fst: In Australia, we don't get the RSX we only get a wannabe type R so parts are neither common nor cheap
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AussieK24 »</TD></TR><TR><TD CLASS="quote">
Custom fabricating parts aren't going to be cheap either
Best of luck though, hope everything works out smoothly...
</TD></TR></TABLE>Custom fabricating parts aren't going to be cheap either
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vteckid33 »</TD></TR><TR><TD CLASS="quote">Go K-series!!!</TD></TR></TABLE>
that would be cool
that would be cool
Hehehe
Should be dummying up the mounts next week. Looks like the gearbox will be coming from Canada, the crank from Florida and the head is next on the agenda
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JCushing »</TD></TR><TR><TD CLASS="quote">maybe you just dont want to saw but i didnt think there was a k series that had a stroke longer than 90.7 rsx s is 86 whats the base rsx stroke is it the same 86mm?</TD></TR></TABLE>
lol... when k-series does not have the stroke you want, look no further then F and H series. These cranks fit, and some people are using the new 04' s2000 crank (@90.7mm)
Anyways... i was thinking about using an F22A/H23 crankshaft... 95 mm
Like you said, i think that 99 is a bit too high and that 90.7 is pretty low. With 95 mm the r/s would be about 1.62 or something, so similar to that of the K20A engine.. therefore you will be able to rev to a decent number, and possibly have an easier time finding a decent camshaft. All this while still having 2.4L on a big-bore.
The only problem is that i posted up that idea on Import Builder's forum, and supposively the crank isnt strong enough to take the power that the k-series will be throwing at it. Someone told me just to take a 90.7mm crank and get it welded to 95mm if that was the stroke i wanted.
Not sure what to do yet, maybe there are ways of beefing up a stock 95mm crankshaft...
