Building a D16
Power goals, money to spend?? First thing you're going to need to replace when you go turbo is your clutch. That's going to give up first (not including the fuel system and other such items you have to upgrade when going turbo).
check out my listings, it has most everything you need to go turbo except for intercooler pipes which any decent muffler shop should be able to make no problem. Here's the link.
https://honda-tech.com/zerothread?id=712229
Drop me a line if you are interested cause I need to sell the parts real soon. thanx.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stu22 »</TD></TR><TR><TD CLASS="quote">I want to build my stock motor in my 95 civic ex, but i dont know wat parts to get, i wanna turbo it. so if anyone knows wat to get then let me know.</TD></TR></TABLE>
If you have to ask, don't do it.
Eagle rods, CP pistons, ARP head studs, ACL bearings, Cosmetic head gasket, new waterpump, timmingbelt, oil pump, new gaskets, hot tank the block, head, and get a crower turbo cam, valves, springs, and retainers. then boost 12-18psi. thats going to be my setup.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bmcc72 »</TD></TR><TR><TD CLASS="quote">Eagle rods, CP pistons, ARP head studs, ACL bearings, Cosmetic head gasket, new waterpump, timmingbelt, oil pump, new gaskets, hot tank the block, head, and get a crower turbo cam, valves, springs, and retainers. then boost 12-18psi. thats going to be my setup. </TD></TR></TABLE>
What turbo parts?
What turbo parts?
