Tranny or clutch problem?
For the past month now whenever I downshift from any gear I really have to force it in and my trany also has a bit of a grind while shifting from 2nd to 3rd gear. Is it my tranny or is my clutch slipping?
what setup have you got?cable or hydro tranny?when was the last time you changed the tranny fluid?how many miles on the clutch?
chris
chris
the grind isn't necessarily the synchro....it may be that the clutch isn't properly adjusted, the clutch is bad, fluid is bad/low/old/wrong kind, OR the synchros. But, since it's harder to get in gear otherwise, it's not the 3rd synchro thats your problem.
I would change fluid, and adjust clutch pedal.
If pedal is too sloppy, and engages the clutch really low, then when the clutch pedal is fully depressed, it doesn't mean the clutch is fully disengaged
It would really be nice if we knew what tranny your talking about.
For all we know it could be a Nissan tranny.
I'll guess SOHC hydro tranny, go with the broken 1-2 shifter fork for $60.
Can I have a clue?
Can I have a clue?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reeder321 »</TD></TR><TR><TD CLASS="quote">Its a SOHC hydro tranny. sorry about that.
Broken 1-2 shifter fork or worn motor mounts, VERY common.
</TD></TR></TABLE>Broken 1-2 shifter fork or worn motor mounts, VERY common.
motor mounts could be getting old as well:
your motor moves around a lot when you shift. If your mounts are old or torn up, when you downshift fast it could move around and cause a small grind. I was thinking about getting energy suspension inserts to help- i have a grind when I shift fast into 3rd from a high rpm in 2nd, and I'm hoping that will help.
Honda synchros notoriously suck *** so theres a pretty good chance your problem starts with them as well.
