NEED HELP!!! Dont think shop installed my Tein properly!!!!!!!!!!!
Well here is the story I had Tein SS installed in my car about 3 weeks ago two days ago I start to here this clunking sound when I drive so this morning on my way to work I the noise is really bad. WHen i got to work I looked under the car to see if I saw anything the result of that was nothing I look in the trunk to my complete suprise the left coilover isnt there. the only thing that is there is the nut and the mount. By this time I am truly pissed so I call a friend who is a mechanic he comes out to my job and pulls out the coilover and installs it properly by this time I notice the coilover is shot. Now my question is what should I do
go back to the shop, and make them buy u a new set
is there any warranties on the coilovers? or did the shop have warranties for installing it?
Sounds like they didn't put all the washers back on. A reputable shop will replace the coilover THEY broke.
I'm still trying to figure out why in the hell you would let a dumbass shop install them and not your friend..
All these posts about shops ****** up and people STILL bring stuff to shops? and coilovers at that? cmon man thats a half hour job. 14mm and a 17mm is all u need.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rewsnaeht »</TD></TR><TR><TD CLASS="quote">All these posts about shops ****** up and people STILL bring stuff to shops? and coilovers at that? cmon man thats a half hour job. 14mm and a 17mm is all u need.</TD></TR></TABLE>
Half hour job?? I think not. Not that tough of a job to do, but honestly, I would say longer than 30 minutes a corner unless you have multiple people working and not taking any brakes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote">
Half hour job?? I think not. Not that tough of a job to do, but honestly, I would say longer than 30 minutes a corner unless you have multiple people working and not taking any brakes.</TD></TR></TABLE>
I can swap out the shock/strut assemblys in 15-20 minutes a side, i just jack one side up and do both the front and back at the same time. I dont see whats so hard about it. and thats with hand tools
remember he got full coilovers so u dont have to **** with a spring compressor or anything.
much longer than a half hour job especially if they are original struts took me three days due to the fact that the bushings had bonded themselves to the bolts i had to cut out the bushings and use a dremel to kill the bushings outer ring, remove them from the trailing arm and the LCA and buy new every thing for the rear suspension ....... I THINK THATS RIGHT?????
well im in florida so i dont have the problem with siezed bolts....and yes 30 minutes not including jacking the car up and ****. the backs is 2 bolts on the bottom and the 2 up top and your done, the front is almost as easy. then again ive takin my shocks in and out of my cars like 30 times so i got it down to a pattern.
some shop have DUMB mechanic
and they dont know ****!!!
last time my rear lca bolt was frozed/rusted, I try to see if those stupid mechanic could torch it out for me and they say that I can not simply replace the bolt and sleeve/bushing. They told me that I'll need a whole new shock with a whole new lca... so...quickly I told him, you guys suck (you guys should of see the look on his face, when I told him they suck)
and then I step out of the stupid shock/alightment shop and done the replacement on my own!!
and they dont know ****!!!last time my rear lca bolt was frozed/rusted, I try to see if those stupid mechanic could torch it out for me and they say that I can not simply replace the bolt and sleeve/bushing. They told me that I'll need a whole new shock with a whole new lca... so...quickly I told him, you guys suck (you guys should of see the look on his face, when I told him they suck)
Screw shops...... I'd rather take on a job I can't handle and **** my car up all on my own, that way there's no one left to blame but my own stupid ***.
I think you guys forget that not everybody is able to work on cars and possess vehicle "know-how" like a lot of H-T members. sometime taking it to a shop is a good decision but.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDMDC2 »</TD></TR><TR><TD CLASS="quote">I'm still trying to figure out why in the hell you would let a dumbass shop install them and not your friend..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jswpstdoff »</TD></TR><TR><TD CLASS="quote">Screw shops...... I'd rather take on a job I can't handle and **** my car up all on my own, that way there's no one left to blame but my own stupid ***.
yes but theres are coilovers. I was doing suspension stuff when i was 15 and i had no clue what i was doing.
remember he got full coilovers so u dont have to **** with a spring compressor or anything.</TD></TR></TABLE>
if im not mistakin i believe u do have to use a spring compressor because your still taking the stock spring and replace them with coilovers
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HXvtec »</TD></TR><TR><TD CLASS="quote">
if im not mistakin i believe u do have to use a spring compressor because your still taking the stock spring and replace them with coilovers</TD></TR></TABLE>
Not with full coilovers...if you just use sleeves and stock shocks, then yes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoulSurfer »</TD></TR><TR><TD CLASS="quote">
Not with full coilovers...if you just use sleeves and stock shocks, then yes.</TD></TR></TABLE>
ok i see what your sayin now. my bad
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rewsnaeht »</TD></TR><TR><TD CLASS="quote">yes but theres are coilovers. I was doing suspension stuff when i was 15 and i had no clue what i was doing.</TD></TR></TABLE>
do you want a cookie or something?
some people get it and some don't or don't want to. oh but i forgot you can do a full coilover job in a half an hour
just sayin springs and **** are about as easy as it gets. it might not take him a half hour but its definately doable.
when i first bought my eh2 i went to a local shop and had my tein ss installed.....the next day i was hearing a knocking noise and was freakin out.....it turned out that the top bolt was not tightened to spec and that they fucked up with the washer order.....i was pissed as **** but i ended up gettin it all figured out......from then on i decided to get **** done myself and if it occurs, **** **** up myself.=no one to blame....thats all i gotta say.
yeah i suck at working on cars, but i think i'm a lot better than some people that get paid. when i first started out, it took me and my retarded friend over 3 hours to install a damn intake
. after working on my own for about 3 months, i've learned a lot, assembled a decent collection of tools, and feel confident enough to tackle anything - provided i have the tools, and a manual so i know what i'm doing and getting into.
get a helms manual and some tools and start changing your oil etc yourself. as long as you're a little bit intelligent, can follow directions, be patient, and pay attention to detail - pretty soon you'll figure it out. **** going to a shop, and paying money just to have them do it wrong anyways.
. after working on my own for about 3 months, i've learned a lot, assembled a decent collection of tools, and feel confident enough to tackle anything - provided i have the tools, and a manual so i know what i'm doing and getting into.get a helms manual and some tools and start changing your oil etc yourself. as long as you're a little bit intelligent, can follow directions, be patient, and pay attention to detail - pretty soon you'll figure it out. **** going to a shop, and paying money just to have them do it wrong anyways.
Guest
Posts: n/a
If you do it by yourself, you will learn something and save some money. I'd just take the car back and speak with manager/supervisor about this issue.
Contact Tein also
Contact Tein also
The stock upper mount is reused with the SS, so they probably did have to disassemble it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bs »</TD></TR><TR><TD CLASS="quote">
The stock upper mount is reused with the SS, so they probably did have to disassemble it.</TD></TR></TABLE>
Touche...I competely forgot about that. Either way, no need for a spring compressor. Just lay it down on the ground, put a towel over it, have your friend stand on it, then loosen the nut. Works for me. Spring compressor is safer though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoulSurfer »</TD></TR><TR><TD CLASS="quote"> A reputable shop will replace the coilover THEY broke.</TD></TR></TABLE>
A reputable one.
A reputable one.
